Page 32 of 36 FirstFirst ... 223031323334 ... LastLast
Results 466 to 480 of 531
Thread: Toyota's Interchangable Oddities.... (TIO#)
  1. #466
    Default Re: Toyota's Interchangable Oddities.... (TIO#)
    Can't remember if this has been raised in here, but was reminded of it the other day so figured it should get put in.
    7K conrods are identical (same part number) to 7AFE rods, which might come in handy for the KE crowd considering you can get aftermarket rods for the 7A quite easily...
  2. #467
    Canada
    Thumbs up Re: Toyota's Interchangable Oddities.... (TIO#)
    From Toyodiy (Corolla 7A-FE): Toyodiy
    13201‑19145
    From Toyodiy (Townace 7K-E): Toyodiy
    13201‑19145
    Wow.
    Mark me stunned!
  3. #468
    May 2010
    Moscow
    I've read recently in some thread here that a Volvo diff bolts up to the RA28. The exact model wasn't mentioned, however it's worth saying that a Jeep locking diff fits Volvo 740/940 rear ends with no modification, and it fits 240 rear end with some machining. You will find plenty at Ebay typing "dana 30 diff"
  4. #469
    Chiba
    Heh, you'll find the Dana 30 and 35 diffs being almost thrown away by the Jeep guys. They are weak and break really easily (well, when used for towing and off road etc anyway).
  5. #470
    May 2010
    Moscow
    that's why I've bought an aftermarket one - Eaton (detroit truetrac) :-) There's actually a wide variety of aftermarket diffs for Dana/Spicer 30 axles.
  6. #471
    Quote Originally Posted by George View Post
    You can use a Volvo diff in a Celica, but they are not "bolt up".
    They need their mounts removed, and have the Celica mounts welded to them just like most other diff conversions.
    ([][][]II--LT--II[][][])
  7. #472
    Junior Member Backyard Mechanic benjamin's Avatar
    Those nice looking Recaro style seats from the Paseo are a bolt in replacement for both 2 and 4 door ep91 Starlets.
    They also drop your bum about 5-10cm and give more knee to steering wheel clearance.
    You will need to use the seat belt buckles from your starlet seats and grind the little wings off the buckles so that the seat slides all the way back and forth.
    I didn't try swapping the belts to the Paseo ones and this may end up being easier than the small amount of grinding.
  8. #473
    Quote Originally Posted by benjamin View Post
    Makes sense when it's the same chassis....
  9. #474
    queensland
    i'm chasing some good quality shocks & lowered springs for a MX32 cressida. by digging thru a lot of old parts books I've found they are supposedly the same as:
    front...
    Celica SA60, 63, RA40
    Corona 1980-87. 132, 133 & 141 models.
    Corolla AE86 "Sprinter" or T18
    rear...........
    Celica SA63, RA65
    cressida MX62, MX73
    Supra MA61
    corona RT142 with IRS
    let me know if you have any , or even if you can confirm fitment. thanks
  10. #475
    Jul 2011
    not quite TIO but close.
    if you happen to split your 89 - 96 2wd hilux radiator (manual gearbox) when you are 350KM from home.. after tearing your hair out.
    you can drop in a vn commonwhore v8 radiator, use vn top hose and a vl turbo bottom hose with minimal fuss and get home no worries!
  11. #476
    I Pity The Grease Monkey the-chief's Avatar
    Quote Originally Posted by CrAiGzEE View Post
    for power steering in a ra23 use a mx62 item (almost bolt up)
    how true is this?? as to almost bolt up and work involved
    "All my life, I have searched for a car that feels a certain way.
    Powerful like a gorilla, yet soft and yielding like a Nerf ball. Now, at last, I have found it"
    Celica, The Car Built for Hulky
  12. #477
    TA22 master cylinder design with the two bolt setup (80mm apart centre to centre) have just become the new standard in toyota's newish models ranging from corolla's, camry's, starle'st and even celica's
    - the EP91 offers a 3/4inch bore twin cylinder (great for a direct replacement of the original single cylinder TA22)
    - i found a neat 7/8 inch unit from a 4 wheel disc brake 1997 corolla (was labelled AE102), which i installed on the TA22 tonight
    - an ACN21 (mid 2000's model something) had a 7/8 inch bore unit which had a remote reservoir attachment. The seals for the reservoir appeared to still be 75mm appart from both cylinders so you should be able to put any of the above reservoir's onto it as they are all 75mm as well
    - we know and love the 1 inch bore on the 20 series camry. well the 36 series camry are the same 1 inch bore, just a diff reservoir shape
    - we saw a late model celica on the roof of another car that we couldn't see the bore size but the bolt setup to the booster was 80mm apart also
    - i also have a 13/16 bore, 80mm two bolt, twin cylinder master cylinder but i can't find it on a factory car. might be for something with rear drums.
    so there are lots of options for a replacement master cylinder for the old TA22 or anything with that two bolt 80mm stud pattern booster
  13. #478
    Feb 2012
    Australia
    Just thought I'd add this, I only got to page 19 and didn't see if it had been mentioned yet.
    RA40 interior door bezels are the same as TA22 - RA28 and FJ40 Landcruisers ( I wanna steal the ones off my brothers Landcruiser )
    You can also buy them brand new from Thailand 'Here'
    NooB 3TGTE swapped RA40
    ✨Rahgo2:Turbo Boogaloo✨
  14. #479
    The Thai bezels are not genuine, and what I would consider single us. They will break next time you try to remove them.
    cheers Chuck.
    MS51Crown Coupe,
  15. #480
    Feb 2012
    Australia
    Sorry =/ Thought it'd be good for people looking to replace crusty, old, broken originals.
