Results 16 to 22 of 22
Thread: side feed injector query
    Default Re: side feed injector query
    ok,
    according to http://www.club4ag.com/faq%20and%20t...ifications.htm
    the silvertop 20 valve uses 295cc 2 ohm injectors (instead of the 1 ohm used by the old 4AGEs)
    i thought they went from high impedence to low, it seems not!
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    1-2 ohms is low imp
    yeah thats what i thought, but terry says they are no good. maybeye that list has the value wrong, ill have to bust out the multimeter.
    i always thought high imp was like 16 ohms, low was 4 or so.
    no idea really
    www.vicdrift.com
    Feb 2007
    Timaru
    Generally anything less than 4 or 5 ohm is low and anything above 10 is high,
    and anything in between is weird or faulty.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    queensland
    thanks guys, correct, its for a specially built 3SG. I used a turbo head & rail for bonnet clearance reasons, and simply forgot about injector impedance as I'm so used to programmable systems (my stuff up). The owner cant afford a custom computer so i'm trying to find a suitable compromise injector, smaller than stock 3SGTE (side feed) and low impedance. The 20V ones in my hand are 13 ohm. I've never seen a 1 ohm 4AG injector. The 162 stock injector was 6 to 9 ohm I believe (but physically checking tomorrow) .
    So therfore I need, low resitance (5-9 ohm), side feed, about 300cc.
    i'll measure mine tomorrow
    www.vicdrift.com
    queensland
    I've fixed it (sort-of). The original 162 injectors turned out to be 13 ohm so we dropped in some stock 20V silver top ones (also 13 ohm) and fixed the over-fueling problem. I'm not convinced they will flow enough, but its a good start. I'm still chasing some alternatives, but at least I've confirmed I'm on the right track. We can get a bit more fule by uprating the pumpm pressure. I'll put a lambda meter on the exhaust, and all will be revealed.
  1. 2JZGTE Tacho Feed
    By BMWTurbo in forum Tech and Conversions
    Last Post: 14-03-2007, 11:06 PM
  2. side feed fuel rail injector spacing
    By -==L=a=N=c=E==- in forum Tech and Conversions
    Last Post: 21-06-2006, 08:10 PM
