Results 1 to 8 of 8
Thread: help with 3sge driveshafts? pics included
    Question help with 3sge driveshafts? pics included
    Hey guys, i searched and stuff, found some helpful information in one of the st162 swap threads, however i still cant seem to remove the passenger (or for that matter the drivers side, which i havent yet tried to remove) driveshafts. any help would be VERY helpful and definately result in rep+
    i've got the hub off, i just cant remove / figure out how to remove the inner joint from the diff
    Default Re: help with 3sge driveshafts? pics included
    put a breaker bar between the gearbox and green part on the driveshaft and lever it out theres a washer/sirclip that drops down and holds it in you so just lever it out with a big screwdriver or breaker bar
    or you can get a big screwdriver in the slit on the green part of the driveshaft and hit the screwdriver with a hammer that will have the same effect i find the breaker bar way easier though
    THANKYOU so much Berad!!! i thought it would be way more complicated than just shove something in there and whack it.. got it out now, thanks mate u gots teh reps dawg
    for the drivers side, undo the two carrier bolts.There sort of a support bracket that holds up the driveshaft. when the bolts are out, pull on it. there a little indent/notch that it sits in. then the driveshaft will just slide out easy,u wont have to lever it out.
    passenger side my explaination was for. if you have to lever the drivers side out theres something very very wrong haha
    Junior Member Domestic Engineer urantia's Avatar
    an easier way to remove the driver side axle is to simply get some pliers onto that giant circlip, really easy to remove and don't have to touch any bolts.
    thanks guys, rep points are flowing
    getting the passenger one back in can sometimes be a major pain in the ass,get some thick ass grease onto it which helps it slide in easier, but more importantly keeps that little circlip centered and pops in much easier.
    Just did it yesterday so all this is still fresh in my mind. save you cursing and breaking stuff in frustration
  1. 1GZ-FE pics and measurements. Drool included.
    Last Post: 27-09-2012, 11:45 AM
  2. Travs 3SGE +turbo RWD conversion
    By TRAV-KE55 in forum Tech and Conversions
    Last Post: 08-09-2010, 07:50 AM
  3. The 3sge oil burner has been pulled down and inspected.
    Last Post: 17-07-2007, 04:15 PM
