no aparantly the size of the sender is different unfortunatley
im going to have a play arround with the vacuum hoses on wednesday and see what i can work out i thought someone might be able to tell me which ones are which from the photo provided
i havent played with the tps but its been suggested that can be an issue
with the bleeding i do just park it so the rear is higher than the front and ive bled the radiator and the heater from what i understand this is pretty much the easiest way to do it
there is definatley coolant in the block now because the water pump is leaking!!!!!!
but yeah pretty sure (fingers crossed) its a vaccume issue
is it the pcv breather on the back of the head in anycase that is blocked atm and i know it has to run to the inlet
there is also a hose on the right hand side in that picture which i think needs to go somewhere
what im worried about is that i might not have the fpr connected properly
neways thanks for the helpfull advice
