Results 16 to 23 of 23
Thread: 2JZ questions
    Default Re: 2JZ questions
    I'll have to take a look into that one... Thanks Ben!
    ([][][]II--LT--II[][][])
    Junior Member 1st year Apprentice kingd's Avatar
    Concerning your box question. The 2JZGTE only ever left the factory in manual form with a V160 6 speed and only ever in a mkIV Supra. So a halfcut that is already manual will be rare and expensive.
    However there are factory bellhousings to fit W5* or R154 boxes to JZ engines. So an auto halfcut + new bellhousing + your choice of box is the best bet.
    Hen
    Am I correct that in thinking I can buy an R154 box inc bellhousing (probably through an importer) and simply bolt this up the the 2J using the clutch/pressure plate/fly wheel set up from the 1J. I understand that I will have to ensure the nissan hydraulic resavour is adequate for the the toyota slave.
    Also how good is the V160? I will use the car for drag work and steet drag meets so it will see plenty of load and shock.
    cheers for all the info thus far
    Yes, if you use an R154 plus flywheel and pressure plate from a 1JZ it will bolt up to a 2JZ.
    The V160 is probably one of the strongest gearboxes in any production car. There are full-weight Supras in the US running 8's with this box.
    No shit... are they a large box compared to the R154? Where would I find dimensions for a this box?
    My Nissan speedo in my R31 worked fine with the 2JZ speed sensor (the 3 wire sensor), it was out by heaps so I used jaycar speedo correctors. The tacho worked fine right away with no stuffing around.
    Quote Originally Posted by kingd
    Farking massive. Below is a pic I took of my V160 compared to a W58, which is slightly smaller than an R154. Note the width towards the rear of the box, this is what gave me dramas when doing the conversion.
    Thats a huge bitch!
    Good to hear about the nissan compatability, most of the S13 and 31 wiring is very similar.
    What sort of money should i look at for an R154?
    Can anyone help me with my management questions? Can i fit the single and injectors on standard 2J (aristo) management?
    only chasing 450 rwhp!!! thats soft - u atleast gotta make more power then my 7m
    so i take it u sold ya ute now hey??
    this a track car or street thrasher??
  1. 1jz to 2jz
    Last Post: 30-11-2006, 07:52 AM
  2. 2JZ damaged, other options?
    By jzk25 in forum Tech and Conversions
    Last Post: 11-07-2006, 06:47 PM
  3. AE82 GZE questions
    By gbanger in forum Tech and Conversions
    Last Post: 07-07-2006, 03:27 PM
  4. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
