Results 16 to 30 of 32
Thread: 1JZ-GTE Soarer runs for 7 sec, then dies - where to start?
    Jan 2007
    Default Re: 1JZ-GTE Soarer runs for 7 sec, then dies - where to start?
    Ah the weekend will be fun. Thanks boys.
    Elmo - Skylines are a piece of cake to work on compared to this thing! (GTR not included)
    Quote Originally Posted by manny
    Typical symptoms of a dying fuel pump ECU in a Soarer
    Simple diagnosis is in the engine bay diagnostic connector, bridge FP to B+ terminals with a thick paperclip to bypass the FP ECU and try starting again.
    Listen to the man.
    Jan 2007
    Are the FP and B+ terminals on the diag plug marked or do i need a wiring diagram to know whats what?
    They are marked.
    Show Us Your Tints Carport Converter Soarer_D00D's Avatar
    Silly question, but does it have enough fuel?
    Quote Originally Posted by eeeyan View Post
    yeah jump start a planet sort of torque
    Jan 2007
    Yeah. Thought it was that. Was running very low. Put 10L in, then another 5L. After filling with the 5L is when it ran for a while 2 days ago, then would only pull 7sec again and again.
    Sadly it's a question you have to ask though. When I was running a dealership in Sydney noone could fix this CRV or HRV honda gearbox, kept slipping intermittently, acting wierd. Drove it round the block, was a bloody CVT. Local auto shop didn't even pick up on it.
    does it stop straight away or slowly dies
    usually if its fuel related it will die slowly
    if theres a lossin power to either ecu coils etc then it will stop suddenly
    ive had 2 soarers play up with bad relays or connections on relays
    one used to get to 6 or 7 kph then suddenly stop
    it was loosing power to ecu
    so if its not fuel related then u need to check powers to all main things like coil and ecu
    its a pain to check anyhting on a soarer
    as they are fukt design with so much electrical shit any work on them takes ages
    id never own one thats for sure even it was for free heheheheheeh
    Jan 2007
    Progress! Thanks for all the ideas guys. 1st thing I tried showed change.
    Bridging FP to B+ on the diagnostic connector in the engine bay allowed the engine to run.
    After the bridge wire was removed, the engine died within about 5 seconds each time.
    Next step? What the hell is a fuel pump ECU, where is it etc? Why can't it just use 1 normal ECU for the EFI like a normal person.?
    soarers run a fuel pump ecu behond the passenger side rear section of trim
    it controls ho and low speed depending on signals form the ecu
    it coul dbe that it could also be the circuit opening relay if its got one plus i thik they also have a fuel pump relay
    as i said they are a pain to work with
    very over engineered pieces of u know what
    so now you have to see if signals are there from ecu or relays
    another thing to check is relays earths ive had them have bad connections in the past
    due to the battery throwing acid everywhere around the base of fuse box
    Jan 2007
    So - is this car just running on the fuel injected during cranking at start up, or does it run the fuel pump with another ECU/trigger for 5-7 sec after startup before using a relay to switch control to the FP ecu?
    Just trying to narrow things down logically before I go on a wild goose chase. We have a running car now, so would like to figure out exactly what the FP and B+ bridging would have eliminated as possible causes.
    Junior Member Backyard Mechanic manny's Avatar
    The bridge between FP and B+ bypasses the fuel pump ECU altogether and runs 12V directly to the fuel pump.
    It's meant to be a temporary diagnostic fix as it will run 12V to the pump constantly even if the engine isn't running, like when you crash the car...
    The fuel pump ecu varies the fuel pump voltage between ~9 and 12 volts during various running conditions via a connection to the EFI ECU.
    Currently your FP ECU appears to be initially priming the pump but then failing to maintain power to the pump once the engine fires.
    There's no COR or fuel pump relay - the fuel pump ECU and EFI ECU manage all the fuel pump control functions on a Soarer.
    The fuel pump ECU can't be readily repaired, so replacement at ~ $200 for a new one or trying your luck on a second hand one is the normal option for the hundreds of prior Soarer onwers in the same position as you.
    GSE20 IS250 - daily
    +b is power frommain relay
    it isnt battery power
    so pump will only work when ecu is on
    are they really 200 bucks new i would expect more
    i know the 2nd hand one i have is worth 150 to 200
    vic
    the supra one doesnt seem to blow up at all , maybe get one of those , staight plug in . id say more like $420 for a new one .
    Dave
    As far as I know they are all the same part number, maybe they updated something internally between the Soarer being released, and the Supra being released.
    $270 new from Rush Imports (when the website is back up)
    Jan 2007
    Thank you very much guys, you have made a potentially painful task exteremely easy. The knowledge and detail has been fantastic. I'll track down a replacement FP ECU.
    Rep points ahoy.
    Last Post: 12-07-2019, 05:11 PM
  2. 1JZ in MA61 NO COLD START?
    By Buttocks in forum Tech and Conversions
    Last Post: 27-06-2006, 10:25 PM
