Would the tacho not work for 2 reasons maybe?
- Incorrect signal shape either square or wave
- Only getting 1 pulse not 4 like standard.
- LeeRoy
I've got a Microtech LT10s with x4 Ignitor box and 4 Bosh coil packs wired up to my AE92 turbo 4age, but now the factory tacho doesn't work. I've tried a few suggestions from other sites and all I could dig up was replacing some resistors and diodes on my factory tacho board, but that didn't work.
One other suggestion I'm yet to try is to add a 1W Rectifier Diode on each negative wire of each coil and a 15V Zener Diode on the wire to the tacho. Also a 1K Resistor to ground.
I've seen this wiring diagram on a few forums, but can anyone confirm for sure this will work for me before I rip my dash out again and butcher some wires?
4AGTE 1990 Corolla SX
- LeeRoy
you need to use one of my tacho boosters which i use on most microtechs
pm me and i can send one COD if you want one
Assuming the AE92 dash tacho was originally fed from a coil negative signal (basically true unless it ran a 4AGZE from factory) you can use either of the following:
- A signal booster from the Microtech tacho output. As seen here. And Viper Nipplex has posted a guide to building one of them.
- 4 diodes, a resistor and a zener on the 4 signals to your coils. As seen here.
Some more info.
Hen
Originally Posted by Hen
Nope.
Almost all toyota 4age's feed the tacho from the EXT terminal on the igniter,
which is not a coil -ve feed.
( although a factory tacho will work from coil -ve )
- KE70 Corolla Dx -
- 500hp+ 7AGTE 20V turbo -
- MRS/Hayabusa turbo **sold**
How much does a tacho booster cost? I think I will try the 4 diodes thing first since I have all the parts anyway. Thanks everyone.
This worked on my ae95 when i fitted my gze
diagram>
