Here's the Audi relay mounted in the driver's side wheelwell using a cable tie. The relay will need to be made water proof later to avoid problems.
Both units mounted. The High one next to the power steering unit and the Low one underneath the headlight:
Both units:
I used existing holes to mount both horns via a washer and nut. The Earthed connections are also attached to these points to make things simpler.
Peter
