plug style and location looks very similar to the speed sensetive powersteering solenoid plug on an JZX81, the ABS sensor plugs are also similar to these.
Anyone know what normally plug's into this?. I've been told it leads to somewhere above the waterpump where there is a male plug. I am 99% certain I don't have the said plug (looked everywhere), Spiller on this forum confirmed his is connected up though.
The Plug in question
It's home in the bay (circled)
On my car it looks like it hasn't been connected for a while, the inside of the plug is very black.
Thinking its a JZA70 thing that wasn't need when the conversion was done *confused*
Unfortunately I can't recall if it used to be connected or not before the engine came out.
Yep indeed.. here is the PS solenoid plug circled in green. I've found that connector and that is in the same location where this other one is meant to connect.Originally Posted by JP
Green = PS plug (female)
Red = Mystery plug (female)
mine aint connected, runs fine.
Elmo.
Wouldn't remember if it was connected in your half cut though would you?Originally Posted by EldarO
yeah it was... i think it mightve been to one of those "resistor" type things you bolt to a ground point, but im not entirely sure.
on the 1J theres not much there, just lights, the air filter, and the hydraulic fan resorvoir.
so if it isnt the lights, you dont need it.
Elmo.
ahh, forgot about those resistor blocks, looks like the one bolted to the tower in this pic: http://www.rollamods.com/gallery/gxjx/chasa341.jpg
a cressida has a plug like it around same area
it is for the 2 speed fuel pump resistor
just bridge the wires if its for that
if the wires are thick blue wire with maybe a red or a black trace then its fuel pump wires
for resistor
on my 1g soarer its connected to just under the distributor. . .dunno what it is though
'88 Soarer GT-L
'90 Supra Aerotop
What are the wire colours?
It could also be the ABS sensor plug - there is a grommet on the strut tower where the other side could poke through to the wheel.
IIRC the fuel pump resistor and relay join to the yellow(ish) plugs near the cruise control actuator, but I could be wrong as it's been a awhile...
Mos.
your spot on here, thats exactly what it is.Originally Posted by Mos
hybrid has worked it out after i told him this on the supra forums
89' MR2 AW11... His
00' MR2 ZZW30... Hers
