Results 16 to 20 of 20
Thread: v6 hilux
    Default Re: v6 hilux
    look at my thread in the conversion section - i have done a series 2 (vp pre ecotec)motor converison. These are better as they have a steel sump which is easier to modify. It also depends on if its 2wd or 4wd as to the costs incurred. The pre ecotec motor has a lot more balls and is very good for a utility..
    Cost also depends on whether you keep it auto or go manual....bellhousings etc arent cheap. I used the commodore auto in mine, with a few mods to the tranny mount it fitted perfect.
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
    new south wales
    Quote Originally Posted by Robbos_Toyotas
    The engines already manual
    tasmania
    sounds like a good buy for a manual. i'd have a good look at it first, and do a compression test on it to be on the safe side. although 300 bucks for the gbox plus shitloads of motor spares is still a good deal.
    all 2WD hilux's came with a G series diff or better i.e. they're really strong e.g. 400+hp.
    go for it, just be prepared to spend extra money on unexpected stuff, and fuel
    beer me!
    new south wales
    Quote Originally Posted by joecoolmk2
    wow 400+ that diff's wasted on my shitty 3Y engine lol, and i'll buy it if it kicks over. But the guy doesnt know if it will, and he just needs a radiator to see if it'll kick it over.
    you dont need a radiator to see if it kicks over...you dont need to run it for long to knwo if its shagged or not...FYI later model hilux lsds bolt in too Or if youre feeling like you want to spend some money, a supra one fits with mods.
  1. changing the gear ratio's in hilux diff.
  2. Alloy Trays on Hilux/ Cruiser/ Hilux 4 door
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 02-03-2006, 06:54 PM
