Results 16 to 30 of 40
Thread: Wolf 3D V4 Software / Link cable
    cruisin in a z30 Automotive Encyclopaedia -=DV=-'s Avatar
    Default Re: Wolf 3D V4 Software / Link cable
    really depends on the motor,eg. my 1g has no problems...perfect idle, better economy than anything ive ever owned and 330 rwhp from an old dieing hks GT2540. what engine are u trying to tune dude?
    JZZ30 Soarer
    wow....only one toyota now, at one point i owned 6....whats happened to me :S
    south australia
    rb25det with forgies, highflow turbo, gtr injectors + rising rate fuel reg.
    The previous owner spent $1200 on dyno time and it still doesnt idle properly or start well when cold, its just hard to tune. Nistune is far superior.
    yeah fair enuff ive never had any real exp fiddling with many rb series motors..having only really owned toyotas or toyota powered cars...dunno mate pull the ecu out, flog it off on ebay and get yourself the latest microleb..apparently its supposed to be a pretty awesome bit of kit.
    JZZ30 Soarer
    south australia
    An ECU with 6 injector drivers will ALWAYS give a better result if you have a proper tuner than batch mode injection with 3 drivers for a 6 cyl motor.
    I'm pretty sceptical of most aftermarket ECUs as a lot of them look good on paper but have crap software, I think I am going to stick with nistune (basically factory ECU with real time tracing and tuneing) and make my own daughterboard for auxiliary IO and boost control.
    Anyway cheers for the replies, will just accept that the wolf is poo and doesn't want to connect.
    Quote Originally Posted by rolls View Post
    lol yeah that is about the subtotal of it, come to think of it, has anybody had any luck connecting and staying connected to these things long enough to really do whats needed?
    JZZ30 Soarer
    south australia
    They stopped building the V4 in 1998 so I dont think anyone really uses them anymore, they are crap hardware and software. The newer V500s are far better, still hard to tune, but once you get it done you can get a pretty awesome result from what Ive heard.
    Victoria, Mt Macedon
    Quote Originally Posted by -=DV=- View Post
    Yeah, I've run a V4 since 2004. Never had any issues connecting, or running. It's been tuned twice professionally plus lots of fiddling with it by me, and haven't run into issues.
    Hen
    I like Stuff Backyard Mechanic mikie's Avatar
    Same here. had the wolf running for quite a few months now.
    i built my 3SGE map from scratch with next to no knowledge. starts runs and stops when i need it to.
    As to tuning its the most simple bit off kit that i have come across. everything is well laid out and you dont need a phd to understand what most of the options menus do. Thats my opinion anyway.
    never had any connection problems even with my ebay serial/usb converter or my home botched cable.
    the only issue i have come across is excess noise coming from the CAS but that probly my wiring.
    Cheers Mike
    south australia
    What else have you used though mikie?
    i have played with autronic, haltec, motec, microtec, link and g-reddy software when i was looking for an aftermarket comp.
    i have used microtec an haltec to tune/change a few bits for friends. Out of that list the only other one that i find usable is the motec.
    once again just my 2c.
    Mike
    south australia
    Yeah motecs are great from what I've heard, the rest Ive heard terrible reports, although I can't talk personally. Always good to hear from others though.
    Forum Member Grease Monkey ap7's Avatar
    I need your help mate, did you manage to sort the below problem? I have the exact problem and am so stuck! Please help!
    Sorry for the epic bump but I have a few questions.
    Wired this cable up, linked it up but it does not connect to the ECU, I am 100% I have wired the pins correctly as mentioned in the opening post. The car stalls when I plug the laptop in and wont start when it is plugged in.
    The wolf lights start flashing funny eg aux in etc start flashing when its plugged in, if I unplug it all is good. The software just keeps saying 'looking for ECU' I have the correct COM port selected and tried various speeds. Is there anything else I need to do? I assume have the cars ignition on is required.
    south australia
    No way in hell that cable was ever going to work, put it on the scope and saw basically nothing even trying to send.
    I ended up selling the piece of crap ECU and getting something decent with 6 injector drivers.
    Quote Originally Posted by ap7 View Post
    How sure are you that the first post is correct? Maybe give wolf a call and see if they will help?
    south australia
    Quote Originally Posted by OnAll-FOUR View Post
    Wolf suggest that you invest in one of their cables or newer ECU products so they can fund their development.
  1. Earth Cable getting hot
    By SilverGhost in forum Tech and Conversions
    Last Post: 26-10-2006, 10:03 PM
  2. How to fix your Jumpy Speedometer
    Last Post: 13-10-2006, 07:58 PM
  3. Wolf 3D V4 Software
    By eezo20v in forum Tech and Conversions
    Last Post: 05-06-2006, 07:36 PM
  4. Replies: 24
    Last Post: 18-04-2006, 02:42 PM
  5. ra23/ra28 linkage to cable for 18rgu
    By krohla-10 in forum Tech and Conversions
    Last Post: 29-03-2006, 01:45 PM
