Results 1 to 7 of 7
Thread: Improving roots SC efficiency??
    Default Improving roots SC efficiency??
    Hey all..
    just having a few thoughts re the toyotas SC12 and SC14..
    obviously they are pretty primitive pieces of kit...
    anyone heard of ppl modifying them to increase their efficiency?, ie, inlets/outlets etc?
    Default Re: Improving roots SC efficiency??
    ive read about people stripping them and smoothing the edges from the inlet/outlet on both sides... apparently it helps
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Water injection pre supercharger helps with sealing and increases efficiency, also absorbs some heat which does not give a higher boost reading but higher air density.
    regards
    jon
    injecting fuel before the blower helps... The fuel acts as a sealing agent on the rotors and as jon said, keeps temperatures down. Im unsure of the structure of a toyota SC but the fuel should also lubricate it to an extent and help it last longer.
    Jun 2006
    Fuel pre supercharger is the go as Jeffro says as it has a greater cooling afficiency, not advised if you are running an intercooler or long inlet tract though as a backfire could be pretty impressive.
    regards
    jon
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    Although not SC12/14 but eaton, see here here and here. Just like heads and inlet manifold, you can match, radius and reshape to improve the efficiency.
    http://www.theoldone.com/sc/jackson-upgrade.html
    http://www.theoldone.com/articles/da...wer/index.html
    http://www.theoldone.com/articles/bl...and-howto.html
    Dan
    I have also seen written in where some gains with an aftermarket blower gained boost running water injection. It on a hyundai in Zoom I think?
  1. 1G-GTE Fuel Efficiency and RA28 Rear Seats
    By twentyEight in forum Tech and Conversions
    Last Post: 12-08-2006, 03:29 PM
  2. 1G-GTE Air/Air Intercooler Efficiency
    Last Post: 08-08-2006, 10:55 AM
