Results 16 to 22 of 22
Thread: Radical changes in fuel pressure with malpassi.
    wanker Backyard Mechanic MS-75's Avatar
    Default Re: Radical changes in fuel pressure with malpassi.
    I'm running 2X044 through two stock regs, and it's odds on the 1FZ reg and 2J reg are the same unit. (when I was running 1x044 I had a single stock reg).
    Try the stock one if you've still got it.
    Sean
    [email protected], WSID, COMPAK ATTAK, MAY 2006
    Nice. Do you have a pressure gauge hooked up? What pressure does it run with the 044 and stock reg?
    It's about 45psi with no vacuum hooked up at idle.
    Even if it's a bit higher than std, because of the relationship between flow and pressure increases you won't see much difference.
    I might just stick the stock one back on for now then. I don't trust the Malpassi.
    When I was running one, I had a guage on the dash and it was perfectly consistant.
    I don't know if I was doing something right or what...
    Also - 50psi base seems high to me..
    2JZR31
    With malpassi and sard I had customers saying there cars run good one day and shit another , I tracked it down to the regs not holding consistant presure , Aeromotive are a bit over $300 plus fuel fittings , And I would say they are a lot better then the other two .
    Trevor
    I think I will put the stock one back on.
    I heard the Sard ones of Ebay are fake? Can anyone confirm or deny?
  1. rising rate fuel regulator-tuning-basics?
    By petespipes in forum Tech and Conversions
    Last Post: 30-01-2007, 09:29 PM
  2. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
  3. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
  4. Replies: 1
