Page 1 of 4 123 ... LastLast
Results 1 to 15 of 56
Thread: Flywheel bolts?!
    Default Flywheel bolts?!
    Quick question, im making the chalkboard a manual today. But i wanna make sure, is it okay to rattle gun the flywheel bolts on? Or should they be done to a certain tourqe?
    Jase
    JZA023
    Default Re: Flywheel bolts?!
    They are meant to be torqued.
    My KE25 thread
    Junior Member Carport Converter 4agte's Avatar
    definatley torqued
    anyone know what tourqe to take them to?
    Jase +repd
    JZA023
    Quote Originally Posted by Smokey228
    No, because you haven't specified which engine.
    4ac, Flywheel torque setting 74nm
    - LeeRoy
    i put red loctite in mine aswell for peice of mind
    Oh yeh, sorry my bad
    Its a 4ac. But cheers for leeroy clearing that up...
    When going from auto to manual, there are two platelets on either side of the auto flywheel. Do you keep these when putting a manual box in or remove them?
    Jase
    JZA023
    Quote Originally Posted by 4agte
    If we're talking about doing up flywheel bolts properly, this is how to do it -
    1. Make sure all the threads are very clean.
    2. Put the flywheel on with all the bolts, hand-tight.
    3. One-by one, remove a single bolt and put some synthetic oil under the head of the bolt. If you don't lubricate the bolt head like that, you will be under-torqing the bolt by up to 30% or so. When that's done, put a drop of Locktite on the thread and replace the bolt with a bit of torque to make sure it's tight.
    4. Go around the flywheel one bolt at a time to make sure they all end up like that.
    5. Do the final torques on all the bolts in the butterfly pattern.
    The reason for putting the bolts in dry first is so that the flywheel is up tight on the back of the crank. It's possible to get some Locktite in between the crank and flywheel, and after a while it'll crank-up and so have the bolts go loose. That's bad.
    So you make sure all the bolts are tight-ish first, then added the Locktite to the bolts one-one.
    www.billzilla.org
    Toymods founding member #3
    Quote Originally Posted by Billzilla
    nice stuff bill
    cheers for that guys... Out of interest, what do you guys use to allign the clutch plate?
    Jase
    JZA023
    CROSSPLANE CRANK! Domestic Engineer Merudo's Avatar
    Jase
    a clutch alignment tool?
    Albeit a socket extension bar works too... or a screwdriver handle
    (i'll probably get ripped into for that one)
    old imput shaft if you have one lying arround
    AU
    Yep nice write up indeed.
    A good point to note is if you torque the bolts without using oil on the inside of the head, you should torque to the required setting and then go a further 70-100deg. This should give you the required torque also.
    Jase
    A clutch aligning tool of course Think supercheap and repco sell these, theyre a little bit nasty but get the job done. 90% plastic, prob $20 or so. A broomstick might work also.
    Ive also used my hands a few times but that gets hard when your under the car.
    - LeeRoy
  1. 5M E to 5M GE/6M GE Conversion Guide
    By spiller in forum Engine & Driveline Conversions
    Last Post: 29-11-2011, 12:03 PM
  2. Reusing flywheel bolts in a 1GGTE.
    By thomasbl in forum Tech and Conversions
    Last Post: 27-12-2006, 10:27 PM
  3. mz11 manual flywheel bolts
    By Johnzoku in forum Tech and Conversions
    Last Post: 26-12-2006, 05:33 PM
  4. Flywheel Bolts 1JZ-GTE R154
    By rogue-vl in forum Tech and Conversions
    Last Post: 26-12-2005, 06:05 PM
