Results 16 to 30 of 56
Thread: Flywheel bolts?!
    Default Re: Flywheel bolts?!
    Quote Originally Posted by Merudo
    a clutch alignment tool?
    Albeit a socket extension bar works too... or a screwdriver handle
    (i'll probably get ripped into for that one)
    Socket extension with suitable socket on works with some clutches. Suggesting that your average person has spare input shafts lying around is an interesting concept
    I'll try the screwdriver handle nextime, my CA18DET clutch didn't go well with the socket method
    Junior Member Carport Converter 4agte's Avatar
    some people might or might know someone that would its heaps easy with a spare input shaft
    Gotta get my hands on a spare input shaft... lol
    But I used an extension and alligned by eye... Was tedious, but not too difficult. But im lazy and love easier ways to do stuff hehehe
    But the tow truck took away the other ae92 with all the gear box bolts. And im pretty sure that the auto box ones are longer, so they wont work. So now i gotta get my hands on a set of Manual gearbox bolts darrrnit! lol
    Jase
    JZA023
    Hey, does anyone know for sure wether or not the manual bolts are interchangeable with the auto bolts? Any can you get bolt sets? Or does someone know where/who i can get some from...???
    Jase
    JZA023
    just bought 1G ones .. 1.95 ea from toyota.
    Black Betty >HERE!<
    (\__/)
    AU
    Crikies that is cheap.. 1JZ flywheel bolts are $9-$10 trade (sheet is at home can't remember exact price)... 8 bolts on a 1JZ flywheel to :S lol
    The actual bellhousing bolts are probably the same, flywheel bolts should be the same for the auto and manual too.
    You can get new flywheel bolts from toyota...
    90105-10042 is the part number for them.. I think that's for a set
    I am the sun
    flywheel bolts and pressure plate bolts were the same. The only bolts i need are the bellhousing ones. And these auto ones i have seem to be too long and too short and too fat and too thin lol
    Unless ive lost the bolts for both boxes entirely hahaha
    Jase
    JZA023
    Bellhousing ones are different between auto and manual I just discovered.. best bet might be to visit a wrecker, or order some new from toyota
    I am the sun
    I tried a wrecker, said they throw them all out straight after removing... Was actualy a real fuck wit about it. Said, "if i sold bolts then id be a bolt shop wouldnt i... No mate, i sell gearboxes...", pretty much just a wanker...
    Tried toyota, and the guy wasnt sure about it, said for me to come down and check out his toyota manual, see if the bolts look like the right ones... And that if the 1 he cant get in, is not important... But i wanted to check if anyone here had a toyota manual so i can see the bolts i need and just buy with part numbers so i dont get the wrong ones...
    Jase
    JZA023
    My bolts were $10.50 each, and i needed 8 I wasn't happy about it at all
    How much does a flywheel that's spinning at a brazillion revs and sawing its way through everything cost?
    www.billzilla.org
    Toymods founding member #3
    Quote Originally Posted by Billzilla
    I realise its important to use the right bolts, don't get me wrong - but $10.50 per bolt is extortion, the margin on that must be massive?
    And in the case of mine, i can't even buy high tensile ones to suit, because nissan chose to use a thread pitch that you literally cannot buy anywhere else. My sisters partner runs a bolt/steel shop and couldn't get them even.
    Feb 2007
    Timaru
    I replace the flywheel bolts on my race engine everytime they are undone.
    I actually ended up buying and machining another flywheel so I dont have to remove them when I swap between my two engines.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    I would suggest new flywheel and pressure plate bolts every time if possible. For a 4AC that would set you back about $20 from your friendly toyota dealer. They are way too easy to break when they are old.
    Get youself a clutch alignment tool from your local clutch shop, my last 'a' series one set me back about $6.50, and make the job heaps easier.
    If the engine is out of the car you can use a broom or screwdriver to lign it up by eye, but it's much easier to use the proper tool.
  1. 5M E to 5M GE/6M GE Conversion Guide
    By spiller in forum Engine & Driveline Conversions
    Last Post: 29-11-2011, 12:03 PM
  2. Reusing flywheel bolts in a 1GGTE.
    By thomasbl in forum Tech and Conversions
    Last Post: 27-12-2006, 10:27 PM
  3. mz11 manual flywheel bolts
    By Johnzoku in forum Tech and Conversions
    Last Post: 26-12-2006, 05:33 PM
  4. Flywheel Bolts 1JZ-GTE R154
    By rogue-vl in forum Tech and Conversions
    Last Post: 26-12-2005, 06:05 PM
