Results 16 to 25 of 25
Thread: Help identifying this 2T-G flywheel
    Hoppers Crossing
    Default Re: Help identifying this 2T-G flywheel
    gasedt18 - pcd for flywheel is same on 2T, 3T and 1G
    dana........definately a TODA...........looks identical to the 4AG one (minus 2 bolt holes)
    Quote Originally Posted by GasedT18
    What is the diameter of the friction surface?
    I'd feel safer, from what I've read, if I had a scatter guard fitted to the bellhousing if I had such a flywheel & if going to be doing serious revs.
    Will have to check that diameter when im at my dad's next.
    I wont be going overboard on the revs as I dont have the bottom end balanced in the engine its going behind, but the engine it was on years back i know it would have seen high revs frequently with either of my parents driving it and they wonder where I got my interest in cars from
    But it held up for a good 8 years with mum's driving and she would have probably been rougher on it than my dad if it held up for her, I should be fine.
    Toyota Car Club (Qld)
    Who greased my Grease Monkey Baref00t's Avatar
    Apr 2007
    Quote Originally Posted by Grega
    When you say 2T, 3T... 2TG only, or single cam 2T as well?? I'm hunting flywheel options for a single cam at the moment, and am not having much luck - if it's interchangable I'll be able to ask around a bit more?
    Hmm... that's like saying "my X3 excel isn't homo, it's got a 4G63 in it!!" A decent motor doesn't make a car less homo. Sorry, just makes you a quick poof!!
    http://www.toymods.net/forums/showthread.php?t=22706
    Photographer and Backyard Mechanic Rinmax's Avatar
    Quote Originally Posted by Baref00t
    They should all be interchangable. Which head it has on shouldn't effect the flywheel.
    "It's an ingenious solution to a problem that should never have existed in the first place." - JM
    "A Ferrari is a scaled down version of god while a Porsche is a Beetle with mustard up its bottom." - JC
    Apr 2007
    Really? how much flexibility is there in flywheel choice?? I assumed things would be fairly specific sizes, and only have limited application from car to car...
    They all run the same flywheel bolt spacing, and all use the same gearbox. They also have the same diameter clutch face (as far as I am aware). So yes, they are ALL interchangeable.
    IF you want a bigger clutch face, you can also use a 1G flywheel, though you would need to use a W5* box, not a T50 box as it wont fit in the bellhousing.
    Word of advice though, you want a 2TG flywheel they are about 7kgs, a 3T and i think 2T is about 12kg and they are a SLUG no fun to drive.
    Apr 2007
    Awesome, cheers for that!
    blah blah celica blah Grease Monkey lt1972's Avatar
    im pretty sure 3t was out in late 75 early 76 for ta23.
    "nineteenseventytwoteeayetwentytwo"
    ..... bye bye baby bye bye .....
    anyone know if those fly wheels still available or something similar? after one for me 3T-GTE
    would be nice
    TODA ones you can still get, from the US or Japan, around $700 from memory?
  1. T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
    Last Post: 29-02-2016, 11:30 AM
  2. comparing 2T and 2T-G standard pistons
    By w810sc in forum Tech and Conversions
    Last Post: 02-01-2007, 05:28 PM
  3. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
  4. 20V Conversion, need to find a flywheel HELP!
    By DeftAnesthetik in forum Tech and Conversions
    Last Post: 14-07-2006, 03:34 PM
