Results 1 to 15 of 18
Thread: 1jzgte problem
    New South Wales
    Default 1jzgte problem
    hey all i have mx83 with a 1jz, at the moment it is not running i stoped about a 1k from my house, the injectors are not earthing out. When trying to start there is ignition at the coils (weak spark) for a second, sometimes kicks over (runs) a little bit. What type of pulse dose the crank position senser give out? .Any help would be appreciated!
    2JEJ Grease Monkey petespipes's Avatar
    Default Re: 1jzgte problem
    Have same car but no experience with electrical problems.[used sideshow for wiring]My advice is to find whoever is available in your area that knows your setup [1j\mx83 or similiar]
    You can ask in a conversation part of the forum who knows a good auto elec or experienced person in your area.I suggest this because many auto elecs charge over $65 dollars an hour and if they dont understand your set up you will be paying for too much time and possibly a "no result"
    [email protected]
    its ok not to know everything
    Roll Ons? Carport Converter Endless's Avatar
    What condition are your coilpacks in... take them out and check for cracks etc, dead one would also be a possibility but it would run like shit once it was started too.
    When did you last change plugs also?
    I suggest pulling the ECU codes!
    New South Wales
    The coil packs are fine. The car is not running because the injectors are not firing, there is fuel pressure. is there anything that will make the ecu not fire the injectors or its the ecu it self?
    Junior Member Grease Monkey BMWTurbo's Avatar
    Jan 2007
    Sounds like a fuel issue to me... My soarer used to do that same when the fuel pump ECU went.
    Quote Originally Posted by Muzza
    if you get the ECU to dump any error codes viathe check-engine light you'll probably work out which sensor or item is snafu.
    pull return fuel line off if theres fue coming out of the engine return pipe then fuel is ok
    thats easiest way to check for fuel
    if you get injection then stop it could be th eignitor not giving an igf signal back to ecu
    weak spark is hard to say if its bad as alot of std efi cars have tiny spark these days
    and thats normal
    try running the enigne on aerostart
    crank signals either work or dont work
    if it nearly runs then crank signals should be ok
    did they hook up the ecu light if they did then check for codes
    Check the engine has good earths.
    New South Wales
    i like your second point side show,when she runs say for a couple of minutes then cut out, she wont start again for a while , i have globe on before a coil and on a injector, when she cuts out there is no power to the injectors and when trying to start it. i will try to see what puslse the igf line has.
    Forum Sponsor Grease Monkey
    Could be dead ecu, seems pretty common on most 1J ecus. They get leaky capacitors which seems to most often affect the injection side of things rather than anything else.
    The last 3 1J ecus i have changed the caps in have had similar problems at least
    What about the ignitor?
    244rwkw / 328hp @ 18psi
    Corona loving Grease Monkey TTMX83's Avatar
    Mine was showing code 14. It was a dead ECU. Same symptoms.
    Try your ECU on another car, if you can, then you can rule it out, or confirm it is the problem.
    Cheers Brad.
    all can be fixed if you show me the money heheheheheeheheheh
    i can borrow ecus and ignitors etc for testing so u dont have to buy them unless yrs are fukt
    but you have to wait afew weeks for me to have some spare time
    i am so flat out i dont get time to do diagnostic work and even when i do i have to charge a good hourly charge otherwise i just go home and watch tv hehehehehe
    New South Wales
    hey, i may be getting a lend a proper scope tomorrow... so in the mean time me and my old man will just try checking different things, but he reckons something is telling the computer to shut off the fuel (injectors).. and the longer you leave it the longer she will run.. (days n weeks)...
    if there is any one who let me put my jza70 computer in there car will be verry helpfull
  1. 1JZGTE problem, rev limiter/ idle
    By GZP51 in forum Tech and Conversions
    Last Post: 24-09-2006, 03:38 PM
  2. Common Problem AE71/KE70 (Now with pics) Headlight/indicator Switch
    By stahlz_ae86 in forum Tech and Conversions
    Last Post: 18-07-2006, 05:13 PM
  3. Ra23 electrical problem.
    By rob1 in forum Tech and Conversions
    Last Post: 17-06-2006, 04:39 PM
