Results 1 to 3 of 3
Thread: A340 gearbox - which speed sensor should I use?
    Default A340 gearbox - which speed sensor should I use?
    As my 1JZ corolla conversion nears completion, I need to wire up the A340 auto gearbox to suit.
    I am fitting a VDO electronic speedometer to the dash, as the A340 box doesn't use a cable drive for the speedo. Problem I have is that there are two speed sensors on the extension housing of the box, one is a magnetic reluctor type (pictured first below), the other is a digital sensor driven from a conventional gear (pictured second)
    Which of these should I use? Is either one better than the other? The VDO gauge can accept either signal.
    Phil
    Default Re: A340 gearbox - which speed sensor should I use?
    u need the top one wired for the auto to change gears properly
    the 3 wire one is for the speedo
    12v ign
    earth
    signal to vdo speedo
    Montrose
    Use the three wire one... or mix'n'match bits from extension housings of other autos to make your original speedo work.
  1. Verifying a w58 gearbox
    Last Post: 09-10-2008, 11:39 PM
  2. IS200 6 Speed gearbox on 1G-GTE?
    By Karma Supra in forum Tech and Conversions
    Last Post: 02-05-2006, 10:47 PM
  3. 5 speed gearbox indentify
    By bullitt in forum Tech and Conversions
    Last Post: 28-03-2006, 09:30 AM
