Page 8 of 19 FirstFirst ... 67891018 ... LastLast
Results 106 to 120 of 284
Thread: How to: Supra MA70 rear discs to Hilux
  1. #106
    Default Re: How to: Supra MA70 rear discs to Hilux
    pete - you dont need any more unions! they are all on the car already, they just need re-positioning....
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
  2. #107
    Quote Originally Posted by Robbos_Toyotas
    My understanding was that I needed the 3 way off the MA70 because it acts as a proportioning valve. If not, no big deal. I noticed there are two unions on the driver's side frame.
    Here's the Hilux (RN85R, built Nov. 1988) brake setup:
    Note that the front outlet from the master cylinder controls the passenger side front, the driver's side front and the rear (through the Load Proportioning Valve or LPV). The rear outlet also goes to the rear axle (also through the LPV).
    In the first photo we see the RN85R master cylinder:
    The front outlet goes down to the three way union below the MC and the rear outlet spirals down to the two way union (located on the driver's side frame behind the three way union.)
    Here are the two unions mentioned above:
    On the three way, the front outlet goes to the driver's side brake. The rear outlet goes along the Lux's frame to the rear. On the two way, it goes straight to the rear.
    Both lines meet up in the green union mounted on the rear frame.
    The top outlet feeds down to another three way union, which sends a line out to the Passenger Side Rear and Driver's Side Rear.
    Peter
  3. #108
    sorry dude when you meant you need a 3 way union i thought u were referring to the one in your 4th pic. You DO still need the brake bias valve thingy i was telling you about tho...the green thing i had pics of i sent to you...
  4. #109
    is a semi-motivated Domestic Engineer 1JZ~lux's Avatar
    mmm... I missed that extra line running to the back when I looked at mine. How would this extra line from the front brakes effect the bias? I was also planning on removing the load sensing when I do my suspension and get the GVM reduced, how would this effect the bias?
    Petrol is for washing parts, alcohol's for drinking but NITRO IS FOR RACING!
    My pictures, Returning some time in the distant future.
    RN85 Hilux + 1JZ-GTE = 298.0HP @ 14PSI -- 60' 1.956 ET 13.775 MPH 99.49
    Project Korruption - Stage 1: The Resto. KE35 Corolla Hardtop daily driver
  5. #110
    Just thought id share my findings, it seems that 90's tarago's share the MA70 rear discs.
  6. #111
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    how much proof do you have?
    measurements, etc? would the backing plate be the same?
    I should be able to get tarago rear disks easy as.
    Andrew
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
  7. #112
    that diagram would look a whole lot better with a line locker
  8. #113
    Herus, toyota part number.
    Cant confirm the backing plate, but if it is different it will just need to be modified differently to to the MA70 one.
  9. #114
    Feb 2007
    Hm...
    Sneaky little toyota..
    Ill look into it this weekend when im at the wreckers..
    Herus
  10. #115
    Quote Originally Posted by Screamn_Sleeka
    I'm going up to Pick'n'Payless this morning. I'll do a quick measure up and visual on the Taragos and report back.
    Peter
  11. #116
    Feb 2007
    Quote Originally Posted by infotechplus
    Peter
    Sweet,
    Thanks Peter
    Andrew
  12. #117
    Quote Originally Posted by Herus
    Sweet,
    Thanks Peter
    Andrew
    Sorry Andrew but there were no 90's Taragos to check out at Pick'n'Payless. Early ones (1980's) were certainly significantly different and unusable.
    Peter
  13. #118
    Feb 2007
    Doh! Thanks for having a look for me anyway!
    Sleeka, Can you link me to where you got all the details from?
    Id like to have a look at a few things.
    Andrew
  14. #119
    This afternoon I began installing the MA70 booster and master cylinder.
    I ordered a new gasket from Castle Hill Toyota, and first they forgot to order it, then they failed to deliver it and eventually I had to go up there and pick it up. To compensate me they gave me a TRD sticker.
    I removed all the brake lines off the original Hilux master cylinder, and undid the four nuts holding it on, and then undid the other four inside the cabin to remove the booster. The only other attachment is a clevis pin and spring clip. Took about 10 minutes.
    Here's the firewall ready to accept the new parts:
    Here's the inside showing the four holes the MA70 booster has to fit through:
    The first problem is that the original Hilux booster has quite long studs, longer than the MA70 booster:
    The Hilux booster is held proud of the firewall by an aluminium spacer about 20mm thick. The MA70 does not have enough thread inside the firewall with this spacer. So I removed about 5mm off it and refitted the booster. Three studs now have enough thread to put the nuts back on.
    The problem now is that the spacer will need to be deleted altogether as the brake light is permanently on due to the break in contact of the stoplight. This means material will need to be removed from the hole in the firewall as there is sufficient interference to not let the MA70 booster go through properly.
    This photo shows the gap that must be closed:
    This is with the horseshoe fitting at its most extended length.
    The MA70 booster and master cylinder fitted up:
    So tomorrow I will have to remove everything again, and take the spacer out, and widen the opening in the firewall. This should be enough to bridge the stoplight gap, and allow all four studs to have their nuts fitted.
    Peter
    Peter
  15. #120
    Whilst I was out at Pick'n'Payless I picked up a couple of items. Namely, the front and rear unions of the MA70 that originally donated my rear calipers and discs. I thought I might be able to use them at some time when re-routing the brake lines.
    The left one is the rear union that sits just near the fuel tank. The right one is down by the driver's side guard in the engine bay.
    This multi-union is off an MX83 Cressida:
    It feeds both front and rear brake lines from just under the master cylinder. It mounts to the guard via two bolts.
    Peter
    By The Witzl in forum FAQ
  2. EF/EL XR Falcon Front & rear disc brakes on a Hilux 2WD ??
    By ICELUX in forum Tech and Conversions
    Last Post: 26-08-2011, 11:08 AM
  3. hilux to supra diff centre interchangability???
    By millsi in forum Tech and Conversions
    Last Post: 17-11-2006, 07:04 PM
