Peter - here it is. This is fucking hard to explain - please wait for my pictures before attempting it - but ill try and explain it as best as i can.
Yeah it isnt the easiest task to do, but heres what i had to do:
Die grind out where the booster shaft goes through the firewall - the Yn57 booster had a central shaft, the ma70 one is upper of the centre. its fiddly, but it works - i dont know if youd have to do this on an rn85 - it could be different.
Now there are two unions down near the drivers side suspension on the chassis rale, above the chassis number (yn57 anyway) - the rear one has one in, one out - for the rear brake. The front one has two outlets - one to the rear of the car, one to the front brake.
what i used was the ma70 brake valve which is attaced to the booster - its a green coloured thing on mine, with the lines already connected into the MC. This then gives you your front/ rear seperation. I got a t piece union, also from the ma70 and connected the front out from the valve to it. i then put the front line that runs accross the car to the pass side into the top of it. There was one leftover line when pulling out the lines on the chassis rail (it had two loops in it), so i used it to go down directly into the drivers side calliper soft line - i discarded the one in, one out union altogether. so that finishes fronts
Rears - i cut off and re welded the one in, two out union to the plate it was on - ie shifted it from the front of the bracket to the rear, used the existing line still hanging there as the feed and connected it into the brake valve rear out - the valve i referred to last paragraph. problem solved..and you got a gucci looking alloy MC and black booster
Ill get photos friday for you....
