im am both impressed and aroused.![]()
gentlemen!
6:52pm, with the gearbox on, the motor was ready for shoving under the car and lifting in!
and 12:10am - the engine is in and sitting on it's two outside mounts! as best i can tell, this is a first for australia!
1992 MR2 GT turbo
2009 Lexus IS-F
Built Australia's first V6 MR2 >> Winner: "I'd Drive It" award - Toyfest '07
Hotness! come to melbourne to give us a ride when its done hehe, Well done man!
vzv21 camry 2vzfe v6 - aka mr burble or white one
Top Effort!! Go the V6's! And yeah come and give me and Timma a ride when your in Melb!
Kind Regards,
Kurt.
1998 ER34 ニッサン スカイラインGT- T
Hoorah! Excellent work man, i've just read the whole build up. Very impressive.
Quick question, though: How high will these motors rev stock / warmed over?
Josh
About 6850RPMOriginally Posted by Javal
Kind Regards,
Kurt.
yup, they cut fuel at 7200.
also, even on stock stock valve springs, they wont float even above that, so with cams they can be made to rev much higher. im not keeping up with the US boards but there are a number ppl on there who were planning to take it to 9k, at least last time i checked.
1992 MR2 GT turbo
2009 Lexus IS-F
good effort dude.. very impressed.. you spoken to a engineer about it ? what was his take on brakes ect
1990 Aus Delivered Widebody GT4 Play 200 awkw
1996 HDJ80. turbo multivalve 80 series landcruiser
1997 HZJ80 Landcruiser Sold![]()
1993 Soarer V8 Manual Sold![]()
1986 Celica SX Sold![]()
This is very cool.
Surprised i havent seen this before.
Would be very fun drive on the old pac
Oh and definetly a long lost brother of Cambelt![]()
BROTHERS!
600 Club Member: Toymods Large Member
MegaP00 - 7MGTE Skunkworks division
RIP - Nathan Dean (TA-022)
thanks dude
no, not yet, i dont imagine brakes will be an issue at this stage, as the car will put out slightly less power than a '90 turbo, and '90 turbo's and '90 aussie N/As have the same brakes.
1992 MR2 GT turbo
2009 Lexus IS-F
blacksupra: cheers! maybe u havent seen it cos this section seems to have very little exposure to the whole board for some reason
haha yeh that may be but i have since got a haircut!
1992 MR2 GT turbo
2009 Lexus IS-F
- got the driveshafts back in - found they wouldnt go unless you do the long one first, then the small one goes in easily... odd? or just me
- crossmember back on, all engine mounts now torqued up
- hubs are both back on, everything torqued except hub-strut bolts, as my torque wrench doesnt go that high. ill take it by the tyre shop down the road when im done.
- brakes reassembled
- heater hoses on
- lower coolant hose sorted (i chopped up the 90' one that was already on that side of the motor, took a few inches off either end and it was perfect to plug straight into the motor
- upper coolant hose nearly done, ive turned the pipe at the bottom of the car around a bit so that it points up to the right, then chopped the U shaped bit off the end of the hard pipe that normally runs up around the firewall behind the airbox. then attached that to (atm) the long pipe it was orignally attached to, and run it up infront of the alternator. however this is too narrow to get onto the inlet where the cap is. have to figure something here, maybe a new hose to replace it or a short piece of hard pipe in between the inlet and that hose.
throttle cable: i noted that the rear brake cable on my pushbike will be long enough to work if i take it under the cam cover... hehe... it has the advantage of having mounting nuts on both ends, unlike the universal kit i bought, however one end still lacks a lug, so i may yet have to use the clamp bolt that came with said kit to join a lug end to it, so that i can get onto the cruise box.
update:
- upper coolant hose finished, went and bought a similar shaped one in a larger size diameter, all hooked up with padding where it rubs things and new clamps
- fuel return done, new hose with new clamps
- fuel feed done, cut the 3S flared bit on an angle as discussed on Oohmatron's thread, yoinked off the 3S feed line, cut the 3VZ flared bit the same, removed shred of remaining fuel hose, popped 3S hose on, crimped it with crimp type clamps (of doom!) and with the fuel filter moved to the top of its bracket the 3S hose reaches with plenty of slack to spare, so no need to change the hose and bugger around with the banjo bolt end. bonus!
- changed fuel filter
- clutch line back on
- gear linkages back on and working
- speedo drive back on
only one photo here cos most of this stuff is boring anyway:
and thats it atm, working on getting the coolant bottle back in place with the expansion tube, thats my goal for tonight,
tommorow (unless i do it tonight) i will be bleeding the clutch, putting the radiator back together with fans and a new LHS hose, then tidy up in the engine bay and start wiring!
1992 MR2 GT turbo
2009 Lexus IS-F
Dude I am in awe.
Will be keenly following future progress, can't wait to see the finished product!
Matt
and it all comes together. nice work Jaemus.
your rep rating is not a reflection of your worth to the community
that's very flattering but no thanks.Originally Posted by H1TMAN
it has breathed its first breath!
official startup 13/3/07 at 7.45pm
afaik, its australia's first V6 MR2, if anyone can prove otherwise please let me know!
its not running properly yet but it fired and ran, and it sounds good!!!
video to come when i get it to run properly![]()
1992 MR2 GT turbo
2009 Lexus IS-F
