Results 1 to 6 of 6
Thread: 18 RC from RA28 to RA40
    Default 18 RC from RA28 to RA40
    Hi all,
    I was just wondering is there any difference in an 18 rc engine from an RA 28 7/77 to an 18rc from RA 40 6/80. I have a RA40 I need to use as a runner and it has a very tired engine. I have a RA28 with an 18rc in good condition but only good for parts.The engine looks identical to the RA 40's. I don't need specs just if anyone could see any problems with the swap.
    Default Re: 18 RC from RA28 to RA40
    I dont think you will find any problems and if there are a couple you should be able to overcome them very easy as the motors are identicle apart from some addded pollution crap.
    will bolt in - literally - gearbox and all.
    remove/disable the emissions shit while the engine is out and make it look stock (e.g. snipped hoses are bad)
    you'll need to notify DoT of the change in engine number - browse their website for method to do this/
    So how do I disable the emissions control. I had a look last night and there is a maze of hoses in there, if I can disable it is it possible to run a different carb , I have a spare 32/28 webber, is it possible to fit this and still run the air/con.
    I would start with disconecting the air pump and removing it for a start if it has one.
    next is the EGR (exhaust gas recirculation) system, just undo it and block it off.
    There are also a few limiters so that the vacuum advance does not work until the engine is up to running temp, just bypass them.
    Thanks Mate,
    I have been working on it today and I think I know what you are talking about. I will have a play and see what happens
  1. RA40 to RA28 exhaust system help please!!!
    By KZN130_Surf in forum Tech and Conversions
    Last Post: 13-01-2007, 07:30 PM
  2. RA40 to RA28 suspension, will it work?
    Last Post: 13-01-2007, 01:51 PM
  3. Exhaust simularities RA40 to RA28
    Last Post: 04-01-2007, 12:07 PM
