Page 6 of 8 FirstFirst ... 45678 LastLast
Results 76 to 90 of 115
Thread: W58 Short shifter
  1. #76
    Default Re: W58 Short shifter
    that may be a better question. im not quite sure what has happened here...how has it been made a short shifter?
    anyone feel like spooning me....sorry, spoon feeding me.
    if not ill get around to googling it one day...
  2. #77
    Instead of a conventional quickshift, where people make a spacer to sit on the top of the shifter housing. What he has done is cut the part off where the shifter ball sits, raised it 18mm for example and then welded it back on with a spacer in the middle. Therefore, using a stock 'cup' i suppose you could call it where the shifter ball sits.
    Good sides; Its easier to assemble and possibly more sturdy over a spacer that sits on the top. And eliminates the 2 C shaped spacers too.
    Bad sides; You can't reverse what you've done. Which isn't a real big deal anyway.
    Here's a picture of a conventional C's quickshift. You can see the round spacer thats made (these can vary in apperance, ie sqaure, circle, etc.) with the two prongs that stick out into the circle in the middle and also the two C shaped spacers that are required.
    Sam
  3. #78
    ta22 madness 1st year Apprentice pryorshazam's Avatar
    Jan 2007
    i extended it 25mm from my measurements off a bought item to suit a 180sx will have pictures of throw length on saturday
  4. #79
    I'd imagine thats a pretty short throw? How does it go on the synchros?
  5. #80
    Jan 2007
    can do any length you want really, syncro wear is goin to depend on the user and if they man handle the thing or not
  6. #81
    Graphic Designer Grease Monkey Petes77celica's Avatar
    quite interested what dollars are we talking dont want want the the shifter to short either about half if not a little shorter can you use standard gear shift knob?
    Cheers Pete
  7. #82
    Great job Pyro! Very neat & tidy.
    So do you feel like making a heap more...?
    Probably at least 20 definate sales too...
  8. #83
    Quote Originally Posted by pryorshazam
    Well most of us here ARE men ya know
  9. #84
    Jan 2007
    if it is to short of a throw you dont have to have it extended so much
  10. #85
    Dec 2006
    Australian Capital Territory
    are u thinking off producing those short shifts? i'm keen on one pending price.
  11. #86
    Great idea pryor* think i'll have a crack at that myself. So that was 20mm right?
    Sorry for the delay, but have had a few issues with getting it right - should have a few more updates shortly. BTW - will be producing heaps and all done properly. Should have some more details and pics of the new one shortly.
    Sorry again for the delays, but getting C&C work done can take time to get my guy to squeeze it in.
  13. #88
    Quote Originally Posted by dallamar
    That's all good, some progress is better than no progress
  14. #89
    im keen if shifter height stays the same
  15. #90
    Quote Originally Posted by naten
    I have talked to the cnc guy and I can get him to make some custom height ones - everything else will be the same. All I need is the numbers that are interested in the longer length ones.
  1. Verifying a w58 gearbox
    Last Post: 09-10-2008, 10:39 PM
