Do you have a test light? If so, earth the clip of the test light and make sure you have an ign supply to the relay. Then, with the clip still earthed, put the test light on the afm wire at the relay and see if the relay clicks. If you have ign but the relay doesn't click with the test light on the afm wire then you have a bad connection at the relay. If it does click, put the test light on the afm wire at the air flow meter plug and see if the relay clicks. If no click then you have a wiring fault on the afm wire, if it clicks you have a problem with the air flow meter or the earth to the air flow meter. Hope this makes sense.
