eyah big chucks on the money. i sort of only thought about "if the suspension guy said the shocks to long". which is what i was getting out with using not only a shorter stroke, shock, but shorter extended length insert.
if the shock is fubar, it's probably bottomed out. as you say. the springs from the laser are not up to it. kings DO nake custom springs. When they say they don't to you, they probably mean they don't have an "off the shelf" item. however, if I'm wrong and kings no longer make customs, i may also have another alternative. there is a daewoo spring that will fit the ke strut. but i'm unsure of the model etc. that you will have to find out at a suspension shop. may even be worth ringing a shop closer to a CBD if the shops in your area are lax. they are a rear spring out of a mid '90's daewoo. and are plenty stiff enough.
failing that, your only option may be to contact a suspension wholesaler/manufacturer direct.
good luck
