Why? Both are 85mm stroke.
Can i usa a 5M crank whith rods and pistons from a 2M in a 2M? or will it be out of balance?
1 MS55 - 3 TA47 - 1 MS123 - 1 YR21(SR21) - 1 RX80 - 1 ST165 - 1 JZS160
as a guess, he happens to have one available/cheap?
Other than that I have no idea about the answer to this question.
RA65 SCCA Car (looking for a decent swap)
NCP61 Daily Driver (pondering the practicalities of making it a SCP61)
Fair point. Yep it fits.
Exactly, I have a couple of 5M cranks and my 2M crank is not so good. And i have a set of new pistons for 2M.
The 5M pistons and rods are about 12-15g heavier than the 2M rods and pistons.
One thing though, I do remember that there is something different about the number 1 main bearing - I think it's wider and need to get it turned down?
It has been a while since I played with these things.
Considered trying to find a 7M crank? You need to do a little more machining to the front of the crank to take the chain drive gear (rather than the cambelt drive).
The no1 main bearing is only wider 84<? I have both 83,84 and 85 cranks (from 5M-E), i noticed that i bearing cap was wider on '85(even on my '84 5M-GE).Originally Posted by gianttomato
Ya, 5/6/7MGE definately have wider number 1 main bearing journal. My recall on the 5ME was a bit hazy - the only one I had seemed to have the wider journal but then others have told me it wasn't wider so I figured there had to be two types.
Personally I would do a 7M crank, 5MGE pistons and a 41013 head (with a lot of work to the exhaust ports). Maybe source an M-D manifold and fit a couple of Weber downdrafts?
Hehe, no no. I couldnt even afford a 7M crank, and i just want to build a "stock" 2M and swap the tired one in my MS55 as soon and sheep as possible.![]()
i gave my old 7M crank away, was in perfect conditionOriginally Posted by johnny blade
Eldar.O.
Johnny BladeOriginally Posted by EldarO
Probably not thick on the ground there.
Should be plenty of 7M cranks in NZ.Originally Posted by johnny blade
my bad!Originally Posted by gianttomato
i just assume everyones at least in aus or nz!
Eldar.O.
