Got anything to back that up? I don't think i've heard of someone destroying an F-series before.Originally Posted by river
I've only heard of the stock LSD centres letting go if abused, but with a TrueTrac they seem near indestructible.
Norbie!
www.norbie.net
My diff broke many years ago, when I was young and foolish and treated the car with disrespect. That was behind a stock 18R-G.
I'm sure there are those around here who have destroyed a F-series diff. As I said, it all depends on how much power you are putting through it and if you abuse it.
Me, being conservative, would go for a G-series to make sure it's robust enough to take any abuse I'm going to throw at it. However, if others feel an F-series would suffice, then so be it.
seeyuzz
river
I think any 30yr old diffs will break if you treat them badly. Put a new TrueTrac and it sounds like you will be fine.
Another factor to consider, where are you going to get a F series live axle from? they came in MX23's which are extremely rare. G series are very common.
Originally Posted by skiddz
Hi guys crownman says he had a welded "F" diff for 2 years with 300 RWHP [race crown[ no probs. fitted to most crowns--from 1968--- disc brakes some 1979 all 1980 and 1981.Regards Steve 0412 711 481.
Originally Posted by Screamn_Sleeka
the F axle also came in the MX13's, and in MS85 & MS112 crowms, the later crown diff has discs BTW
beer me!
i reckon the G diff really would be easier, considering they were more widely used. there's more ratios available, and more LSD options. they would be easier to get hold of, probly for about the same price maybe a bit more, and most/all of them are 5 stud pattern giving better choice of wheels.
beer me!
Originally Posted by SIKTOY
This is the correct answer.Originally Posted by gianttomato
You make no mention of your intended application.
I'm organising trutrac LSDs for these at $650 a pop.Originally Posted by joecoolmk2
my 200+rwkw 1jz didn't do any damage to the f-series, norbie hasn't broken one with his 2j.. I'd say a 1g won't be killing a trutrac f-series any time soon.
My mate has an F series with a Cusco 2 way in a 3sgte powered ae71. It runs a twin plate os giken clutch and pumps out 250kw. This thing gets its arse reamed everyday with 4th gear reclutches and all the hoo haa and the diff hasnt even started making noises.
- LeeRoy
What car is the big question. G series has a more available range of widths so no point going F series from say a Crown if your wheels are going to sit half a mile out the guards.
Callum
Its going itno a RA40 so 1410 wide is needed
Thanks heeps for all the advice fellas
reputation is nothing knowledge is everything
RA23 1GGTE 12.3@110mph
1980 RA40 now getting a 1G with new picsLOOK
Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
probly easiest to find a 1410mm hilux (RN4x) diff - G series.
im running a MX13 in the GA40 at the moment, no breakages yet.
although ill be using a MS112 diff in the next RA40
tarago F series is also an option
hello
Brett
Whats the diffarence in the mx13 to the ms112
MX13 = 4-stud with drums
MS112 = 5-stud with discs
EDIT: the Toyota Axle Database has all the answers!
http://toyotaaxle.norbie.net/AxleList.aspx?SeriesCode=F
Norbie!
www.norbie.net
