Results 16 to 30 of 54
Thread: F series diff
    Default Re: F series diff
    I've only heard of the stock LSD centres letting go if abused, but with a TrueTrac they seem near indestructible.
    TAS
    Quote Originally Posted by river
    An F-series won't last too long behind that power, especially if you drop the clutch and give it a hard time.
    Got anything to back that up? I don't think i've heard of someone destroying an F-series before.
    My diff broke many years ago, when I was young and foolish and treated the car with disrespect. That was behind a stock 18R-G.
    I'm sure there are those around here who have destroyed a F-series diff. As I said, it all depends on how much power you are putting through it and if you abuse it.
    Me, being conservative, would go for a G-series to make sure it's robust enough to take any abuse I'm going to throw at it. However, if others feel an F-series would suffice, then so be it.
    seeyuzz
    river
    I think any 30yr old diffs will break if you treat them badly. Put a new TrueTrac and it sounds like you will be fine.
    Another factor to consider, where are you going to get a F series live axle from? they came in MX23's which are extremely rare. G series are very common.
    Smile Re: F series diff
    Hi guys crownman says he had a welded "F" diff for 2 years with 300 RWHP [race crown[ no probs. fitted to most crowns--from 1968--- disc brakes some 1979 all 1980 and 1981.Regards Steve 0412 711 481.
    tasmania
    Quote Originally Posted by Screamn_Sleeka
    the F axle also came in the MX13's, and in MS85 & MS112 crowms, the later crown diff has discs BTW
    beer me!
    tasmania
    i reckon the G diff really would be easier, considering they were more widely used. there's more ratios available, and more LSD options. they would be easier to get hold of, probly for about the same price maybe a bit more, and most/all of them are 5 stud pattern giving better choice of wheels.
    beer me!
    Quote Originally Posted by SIKTOY
    How strong are they compared to the g series
    Quote Originally Posted by gianttomato
    Less strong.
    This is the correct answer.
    You make no mention of your intended application.
    Quote Originally Posted by joecoolmk2
    more LSD options.
    I'm organising trutrac LSDs for these at $650 a pop.
    my 200+rwkw 1jz didn't do any damage to the f-series, norbie hasn't broken one with his 2j.. I'd say a 1g won't be killing a trutrac f-series any time soon.
    My mate has an F series with a Cusco 2 way in a 3sgte powered ae71. It runs a twin plate os giken clutch and pumps out 250kw. This thing gets its arse reamed everyday with 4th gear reclutches and all the hoo haa and the diff hasnt even started making noises.
    - LeeRoy
    New Zealand
    What car is the big question. G series has a more available range of widths so no point going F series from say a Crown if your wheels are going to sit half a mile out the guards.
    Callum
    Junior Member Backyard Mechanic SIKTOY's Avatar
    Its going itno a RA40 so 1410 wide is needed
    Thanks heeps for all the advice fellas
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    User Conversion King
    NWA
    probly easiest to find a 1410mm hilux (RN4x) diff - G series.
    im running a MX13 in the GA40 at the moment, no breakages yet.
    although ill be using a MS112 diff in the next RA40
    tarago F series is also an option
    hello
    Brett
    Whats the diffarence in the mx13 to the ms112
    MX13 = 4-stud with drums
    MS112 = 5-stud with discs
    EDIT: the Toyota Axle Database has all the answers!
    http://toyotaaxle.norbie.net/AxleList.aspx?SeriesCode=F
  1. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  2. s series diff info needed
    By styler in forum Tech and Conversions
    Last Post: 04-12-2006, 02:40 PM
  3. F series Diff . P51 box and likely sources for GT parts.
    Last Post: 12-10-2006, 09:58 AM
  4. G series diff database
    By bansheebuzz in forum Tech and Conversions
    Last Post: 01-05-2006, 10:36 PM
