There are a few things you need to think about when turbocharging an NA engine
The engine will detonate at its torque peak, which is also where peak cylinder pressure is.
Ways to reduce the cylinder pressure or help control detonation with high compression are:
- Bigger camshafts/more duartion
- Cam gears
- Short runner intake manifold
- My favourite, well designed exhaust manifold and bigger turbo
The bigger you make the turbine side of the turbo system, and the better than manifold is designed to lower back pressure, the less chance you will have with detonation. While I'm happy for you to prove me wrong, I Personally don't think you'll make anywhere near 250whp on 11psi of boost, a similarly modified SR20 turbo engine only makes that sort of power on 20psi, I'd expect maybe 160-180hp with that turbo.
Tuning will be critical, I would be going a better computer than microtech, but if you do, get a very VERY good tuner pressing the buttons on the dyno, high comp and turbo's are not happy partners. Oh, and I highly recommend SHell V Power Racing 100 octane fuel, worth about 4 degrees of timing over 98ron.
6BOOST
