Results 1 to 15 of 16
Thread: now strut identification
    Default now strut identification
    Can anyone pick what this steering rack is out of?
    I'm assuming its toyota but have nothing to compare with at the moment.
    vic
    Default Re: Rack identification
    Thats VB commodore there
    Dave
    was gunna say judging by the mounting method it looks like the rack Pube on here put in his celica.
    commyWhore.
    Black Betty >HERE!<
    (\__/)
    Ok thats yuk.
    Might have to go look at a ke70 one or something
    nothing wrong with the racks ... plenty around .. lotsa aftermarket support etc.
    Black Betty >HERE!<
    (\__/)
    pics of rest of car,
    that custom front end has me curious
    Thanx for the quick identification guys. It has got no steering column so i'll be looking into it all a lot further before i change anything.
    Quote Originally Posted by merc-blue
    Yeah that's why i got it.
    I haven't taken photos of the whole car yet but it just looks like an ordinary KE20. Was built a long time ago from what i know. Don't know what motor was planned for it but it cant have been too big.
    Tube chassis only goes half way along car.
    A little help identifying the diff & front hubs would be good too. Spring mounts have been welded to the diff & it just looks like a later model but its been awhile since I've had a car later than a KE20.
    I think front disc looks like ke30?
    Default Re: Rack identification & more
    Here is the car
    Still need to identify what struts are and the diff.
    Stub size i think is the same as some ke70 bearings i have here.
    The tubes are 270mm tall.
    Here is the bottom of the strut. Hole centres are 85mm.
    And what diff is this? its 10 bolt & the centre is 210mm & its 1220mm wide.
    At Work I'm A Grease Monkey Hibba's Avatar
    Default Re: Rack identification and other parts
    Diff could possibly be a shortened commodore one?
    MX83 Grande
    DirtyWan Skyline GX
    Nah i think its toyota. Would just like to know what its from. Only mods are removing old mounts & welding new ones on it seems.
    Edit: thinking about it i think it may be just a t series diff but its been awhile since ive looked at one
    This is an early commodore rack. They arnt a bad choice as they are easy to cut down and mount. They are used in the states so there are plenty of parts around and you can get just about any uni joint to suit any column. I got on to suit the commodore rack to the ke70 double-D shaft. They pic you posted looks like a similar rack.
    Thanx guys ive confirmed that its VB commodore as i found some markings that say TRW & the part number.
    So the ke70 shaft fits? I might grab one and see how it goes into a KE20.
    Still need to identify the struts as it would help setting up some brakes.
    Default Re: now strut identification
    Ok after lots of measuring and searches the discs seem to be corona RT80 or Celica TA22.
    Ive found measurements of the TA22 strut & mine are heaps shorter. They may have been shortened but they are original oil with no insert.
    I cant find a measurement for the lower bolts on a TA22 strut can anyone help?
    struts are custom/modded no doubt about it
    Yeah i just pulled one apart and i think the original rod may have been shortened & re threaded.
    Is this a TA22 part? I havent been able to find a photo.
  1. TA22 + rack and pinion
    By "Z" UTE in forum Tech and Conversions
    Last Post: 19-05-2017, 11:02 AM
  2. JZA70 steering rack leak
    By beatle in forum Tech and Conversions
    Last Post: 17-12-2006, 05:42 PM
  3. Power steering rack help
    By Johnzoku in forum Tech and Conversions
    Last Post: 23-11-2006, 12:06 AM
  4. 162 Celica Steering Rack Help!!!!!!!!!!
    Last Post: 03-05-2006, 05:43 PM
  5. Help Needed to identify Steering Rack
    By Art Racing in forum Tech and Conversions
    Last Post: 10-03-2006, 06:32 PM
