Results 16 to 23 of 23
Thread: Brake Troubleshooting
    Default Re: Brake Troubleshooting
    nope nope nope
    you have air trapped in your master cylinder.
    you need to bench bleed it, then install
    all your woes will be gone
    trust me, same issue i had in a ke70 when i had the system empty then put the ra60 and twin spot alfa rear calipers on.
    if a ke70 MC can power them, the starlet one can power your piss all larger starlet brakes
    Well the guys down at ABS bleed my brakes too and that didnt make any difference either, so im still saying its the MC.
    Whats bench bleeding though? I've never heard of it.
    http://www.misterfixit.com/brakbld1.htm
    same applies for when the MC has been drained, im assuming this one has, as most people dont think to clamp theyre brake lines when taking calipers off...
    http://www.google.com.au/search?hl=e...cylinder&meta=
    for some further reading
    i got my mc bled when i took it to b&r brakes (a toymods sponsor)
    they just disconnected the brakes likes from the master cylinder and pumped fluid straight out of the mc.
    actually they didnt disconnect the lines completely, just losenes one at a time until the fluid can escape.
    they sprayed water on the areas around the mc first to protect everything and gave it a good rinse afterwards also...
    well yes, that would work
    thanks guys, i will be sure to bench bleed the new master cyl before i put it on
    Tasmania
    Also has anyone thought of checking the proportioning valve?
    why would that be making the pedal hit the floor?
    serious question, never dealt with propportioning valves before...
    By The Witzl in forum FAQ
  2. Disc Brake conversion of Live Axle RT104 RA40
    Last Post: 18-05-2011, 02:50 AM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
  4. Brake upgrades for FWD/AWD 5x100
    Last Post: 06-09-2005, 11:38 PM
