hmm, you are losing 10% torque from 4000-5700 ish..
if it was flat, it would be all you could hope for
for power, cos you are losing torque, the poer could be 10% higher at max rpm... but it doesn;t look that bad![]()
from 4000 to 5700, you are increasing flow (hp) by 33%, whereas ideally, you would increase by 43% maybe (assuming you are making max torque at 4000)
11.5 is fairly rich.. could the boost + rich mixture be making it harder to ignite?
if you hit cams limit, it should drop off faster. if you hit valve float, it should be similar.. fast change with rpm.
it could be a number of little things adding up, but you are getting 75% of the increase in power from 4000 to 5700 that you could/should be getting..
oh, before you go all spendy on a new IC... measure the pressure drop across it (ie from the piping before and after it) if not much pressure drop no need to replace (unless temps go up)
actually, it would be very informative to hook up two pressure gauges, one to each side of IC, and give it a bootful.. if one goes up faster than the other, then it has issues..
they work for me
