Results 1 to 6 of 6
Thread: Carmy ignition barrel ..
    Junior Member Grease Monkey Les's Avatar
    NSw
    Default Carmy ignition barrel ..
    96 camry vienta
    Search came up with this http://www.toymods.net/forums/showth...ht=lock+barrel
    I think it is the same problem ... symptoms are similar.
    Key in .. turn .. WTF no work ?!?! 5 or 10 minutes later, OK .. working perfectly.
    Could it be anything other then the key barrel ? i.e. immobiliser etc. or will getting the lock re-wafered the way to go ?
    Thanks ...
    2003 Clio Sport 172 N/A
    1985 RA65 Celica T/T
    1983 AE86 Levin Sprinter S/C
    1997 Lancer RICE
    wa
    Default Re: Carmy ignition barrel ..
    try getting a new key or try a spare key sometimes the key will become worn down and sometimes will turn the ignition and sometimes wont
    if this doesnt work i would get a new barrel
    NSw
    I did not mention that it did not even turn the first notch to Acc (or is it On).
    Swapping keys working for now, so is it key or barrel you guys reckon?
    1997 Lancer RICE
    wa
    keep trying the spare key if it fails then get a new barrell
    NSw
    HAH I keep failing to tell you something !!
    THE main key will play up and the spare will work .. so the next time, I will use the spare - which would fail - then use the main and THAT would work !!
    Common sense says barrel huh ?
    1997 Lancer RICE
    wa
    yeah mate definately barrell
    get a new barrel and key and fit it yourself they are not hard
    when you need to code the new key post here or send me a pm and i can tell you the procedure
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 02:42 AM
  2. Replies: 5
    Last Post: 21-12-2006, 10:46 AM
  3. Ignition Switch
    By rj_darlow in forum Tech and Conversions
    Last Post: 20-10-2006, 12:48 PM
  4. Replies: 0
    Last Post: 20-07-2006, 01:18 PM
