Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: ADR 15 - Demisting of Windscreen
    Default Re: ADR 15 - Demisting of Windscreen
    a number of the newer euro vehicles use a small 12v heater in the internal blower system so tat you get warm air frm the moment youstart the car without having to wait for the coolant to warm up... thought about adapting one of these units ?
    Again, though, you've spoken about 2 race cars, not something you can get normally road registered (& no, rally cars are not "normally" road registered like other vehicles).
    I like the 12v heater thing built in though. Would be very handy in Europe where it could take a while to warm up the "coolant"
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    hey i have looked into replacing the heater box in my rolla with 2 electric heaters mounted under the dash blowing up through the existing demister vents. should connect up with a short fabricated adapter and some wiring. will be much lighter, problem free and work instantly on cold days when there is bad misting up.
    only thing im trying to work out is if it will be sufficent enough, apparently the water heater boxes put out a load more heating power than an electric one but i think 2 electric ones may do. i will find out shortly when i put them in lol...
    Gravel Lover Backyard Mechanic stumpygt4's Avatar
    Well for competition cars it states in the cams manual that you may remove the original demister, but must retain an electronic demisting device. This year they added “must not impede the driver’s vision in any manner"
    I am going to buy one from http://rallynuts.com/motorsport/, they have a blower for around $90 or so. Its cheeper than having a heated windscreen for $1000.
    Jeff
    Jeff Thomas
    TOYOTA TEAM CELICA
    1 x 1989 ST165 rally car, 1 x 1988 ST165 GT4 spare car & 1 ST185 khana cross car. (for now )
    1 x GT86
    <useless triva>
    A lot of cars in hot places like Malaysia, Indonesia, etc, are not fitted from the factory with heater boxes. There's no hot or warm air selection available on the panel.
    I've got a photo of one somewhere, I just can't find it sorry
    </useless triva>
    www.billzilla.org
    Toymods founding member #3
    Found it!
    www.billzilla.org
    Might be interested in looking into these heaters. Looking at buying a car where they had to sacrifice the A/C (which sits underneath the heater box) to fit a trans tunnel in. If I can make the heater samller, I just might be able to fit the A/C core back in
    Also might have to find the picture of a car's dash in Euro where they didn't have a "cold" setting, nor A/C
  8. #38
    Wodner how i missed this thread...
    anyway, i work for an OEM automotive air conditioning company and until recently the only ADR we had to comply to was ADR 15.
    to be honest, i'm not sure what rule there is now, i think it is something like "you should probably be able to demist the front windscreen"
    car companies have their own specicications that cover defrost/defog/demist, so new cars will always have something for seeing out the front window.
    A/C actually works a lot better than a heater to defog the windscreen, as the "dry" air coming out of the vents "sucks up" the moisture off the windscreen and clears it. hot air has to heat up the windscreen to the point the moisture will evaporate, but you need a heater for de-ice etc.
    Bill, we do a few A/C only kits for SE asia (no heater) and we do/have done heater only kits for other parts of the world.
    best way to clear your windscreen is with dry air (fresh not recirc) A/C on and the heater on.
    having said that, i think the 12 volt hairdriers are a great idea and you could plumb them in to your existing demist vents without too much trouble, also you can buy electric elements designed specifically for heating air, we use them in diesel cars as they don;t produce much heat. they are pissweak compared to a normal heater core, but would help get the job done.
    as for me, i will always run a heater, as its otherwise wasted energy and i know how bitter a car can get without a heater, after re-installing my ECU into my car i decided to leave the blower off to save some time, then drove to benalla with freezing air blowing in through a hole i couldn;t block off, it sucked!
    hope that helps in some way, i might look into the whole ADR15 thing a bit more
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
  9. #39
    If you go to the rallynuts website, go to Shop By Brand, then look under Pacet Fans. That is where the blower is.
    Jeff
    Jeff Thomas
    TOYOTA TEAM CELICA
    1 x GT86
  1. Replies: 4
    Last Post: 13-03-2006, 09:35 AM
  2. Rubber mounted windscreen installation - without the heartache
    By o_man_ra23 in forum Tech and Conversions
    Last Post: 17-01-2006, 10:55 AM
  3. KE70 Windscreen - Alternatives to Chrome Trim
    By WDE_BDY in forum Tech and Conversions
    Last Post: 31-12-2005, 03:48 PM
