Results 1 to 5 of 5
Thread: What clutch to run with T50 box on K-series engine?
    Emo Slayer Backyard Mechanic rollin_stock's Avatar
    South Aust
    Default What clutch to run with T50 box on K-series engine?
    Im looking at buying a clutch so I can use my T50 gearbox, it has a K-series adapter. Does anyone know what clutch I have to use, there was no clutch with the box when I bought it. The engine is a 5K. I can get photos if there are different T50's.
    If anyone can shed any light on this, part no's/models etc., much appreciated!
    Default Re: What clutch to run with T50 box on K-series engine?
    a friend of mine got the 5K flywheel lightened and modified to take an AE86 clutch (the small one i guess), although his box was from a KE35 so i think the input shaft was different andhad to get the friction plate centre swapped?
    something like that....
    i think he may have had to slightly relieve the inside of the bellhousing also, but it was the cable clutch BH, not the hydraulic
    New Zealand
    clutch from a ke74
    unfortunatly i doubt ya local has listings for that.
    try these p/n
    31210-12180
    31250-12122
    they probably supercede. they from a ke74, 5k and t50.
    if you have issues over there i can supply you one.
    a customer of mine is running a 4k with t50. he did the research and ordered the bits off me.
    clutch cover was a ep71 starlet. i cant recall exactly that the plate was from though
    Victoria, Mt Macedon
    Talk to any competent clutch shop. If you take in a T50 input shaft (or a clutch plate which suits the shaft) and the flywheel then they will be able to either find a suitable clutch off the shelf, or get something custom made. Turnaround should only be a couple of days.
    Hen
    South Aust
    Thanks guys, see how I go at Xtreme Clutches, hopefully they can cross reference from those part no.s for a Ke74. I will let you know what fits!
  1. Toyota Engine Codes Explained
    By wagonist in forum FAQ
    Last Post: 16-12-2015, 11:21 AM
  2. Toyota R Engine History
  3. MA70 --> JZA70 Conversion
