Results 16 to 30 of 39
Thread: 3S-GTE differences??
    Junior Member Grease Monkey cycleofabuse's Avatar
    Default Re: 3S-GTE differences??
    Quote Originally Posted by Wildsupra
    Are the 2 motors identical in physical size? and do they bolt up to the same mounts?
    Basically if i build mounts to fit my 165 motor in then later down the track bought a 185 motor would it be a simple bolt out bolt in situation?
    Yeah they will both bolt in the same.
    W.A.
    Quote Originally Posted by hamgatan
    why do i get the impression im likely to bump into you again on malaga dve in a 3SGTE powered AW11 sometime soon?
    HAHAH i dunno, do you normally predict the future MWUHAHAHHAHAHA
    Matty
    well i have a 165 motor and im gonna chirp in and say that the power differences between 1st and 2nd gen are pretty small, and that my 165 motor stock goes harder then an 185 motor stock and all i have is turbo work done, and it is quite happy to run 12 psi also the WTA cooler doesnt suffer from heat soak issues as on the 185 motors... also i ran 14 psi on my motor after having the headgasket done and the like and i have to say my car was one quick lil car (its an st162 ) just tryin to keep the 1st gen rep up
    there is a 10 HP power difference between 1st and 2nd gen.... so take that
    W.A.
    Quote Originally Posted by Jorrs
    Respekt!!!!
    Thankyou my good man, you have made me feel much better about going to all the effort to install my "lower" power 3S-GTE
    10hp pff i'l just remove the air filter to gain back the 10hp
    Matty
    I also have a 165 motor with stock internals and regulary run over 30 lbs boost , I have put out 272 RWKW and 1/4 mile 11.89 @ 126 mph on 205/60/13 street tyres .
    Trevor
    Except if it's a JDM engine, then it's more like 35 HP. Gen I in KW are 140 and gen II JDM are 165-7 if I'm not mistaken.
    Check this link for differences:
    http://gtfour.supras.org.nz/3sgte%20table.htm
    Yes a Gen 2 will bolt in where a Gen 1 was mounted. It will need a complete rewire though as far as I know.
    Having seen several different generation 3S's on the dyno and driven a few myself I still can't say the Gen 1 is any good. They just don't seem to turn numbers even comparable to the later engines and feel extremely strangled and uninspiring to drive. Sure TA22-3SGTE is making big power out of one but it isn't stock doesn't run stock management or stock turbo.
    In an AW11 a Gen 1 will be reasonably spritely but it won't blow your socks off. My 3S powered AW11 makes 200rwKW on 10psi and I am planning on getting it tuned for another 10psi asap. That is pretty damn far from a stock engine though, and it's a Gen 3 origonally.
    i think gen 1s are 145 ? and gen 2s are 153 ? anyway well yeh i dunno its not such a bad engine, i like it and my car is by no means slow but yeh each to their own
    define slow...
    good question, how should we define slow ?
    W.A.
    Quote Originally Posted by TA22-3SGTE
    Trevor
    is that all?? HAHAHA
    Hmm well i think if i could achive those sort of times in a 3S powered MR2 i would be more than happy
    I think my decision is to install the engine i have currently then if for some reason i cant get it to perform as i would like it too, i will simply upgrade it later.
    My first aim will be to run 11.88, just so i can beat TA22-3S-GTE heheh
    Matty
    W.A.
    Hmm well how about the old scenario "yeah mate i got a V6 commo mate and its hella fast" ok so a V6 commo is obviously the definition of slow.
    Lets now define reasonably quick?
    And well i think TA22-3S-GTE has already defined fast for us
    Matty
    lol yes that should do it
    that would define it quiet nicely but that engine is a freak. not to knock the gen 1 in any way but the average gen 1 wont take that kind of shit. but thats not to say there a bad engine, but the gen 2is just a beter alternative for much the same money, newer more powerful etc etc.
  1. 5S FE to 3S GE
    By adam golder in forum Tech and Conversions
    Last Post: 05-10-2007, 09:47 PM
  2. 3s rwd conversion parts, what else needed?
    By CoronaC in forum Tech and Conversions
    Last Post: 11-01-2006, 07:43 AM
  3. 6M and 7M differences???
    By fatboy13 in forum Tech and Conversions
    Last Post: 10-01-2006, 07:20 PM
  4. 3S BEAMS & 6 speed Altezza gear box into KE30 chassie
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 03-01-2006, 10:59 PM
  5. Replies: 0
    Last Post: 30-08-2005, 08:43 AM
