Data shows somewhat convincingly that Compression and Boost follow a couple of basic principles:
A) For every point of compression you raise an engine you gain 3.2% power potential.
B) For every 1psi of boost you feed an engine you gain 3.5% power potential.
I use the words 'power potential' as these gains rely on tuning ability to take them from theoretical to practical!
To illustrate, consider the following example:
For a given engine combination in which nothing but compression is changed physically and of course basic fuel and ignition tuning.
12:1 compression being boosted 20psi gives 28:1 effective compression.
7:1 compression being boosted 45psi gives 28:1 effective compression.
Now just for arguments sake lets say for the 'control' fuel being used 28:1 effective compression is the highest level safely achievable in these motors before detonation creeps in.
As the 7:1 compression motor is 5 compression points less, it is already down 16% power potential on the 12:1 compression motor.
Since the 7:1 compression motor needs 25psi more than the 12:1 compression motor to see the same effective compression it is up 87% in power potential.
Taking the 16% compression loss away from the 7:1 motor leaves it with 71% greater power potential at the exact same 28:1 effective compression. In essence it takes 5psi more boost at any given point to make the same power with 7:1 compression than with 12:1 compression and each psi more boost from there is pure profit!
Note: Assuming the power adder of choice is turbocharging, the above example allows for tailoring the choice of turbo/s and configurations of such to maximise the potential of each engine combination.
For a more technical explanation of the above condensed information go to:
http://www.modularfords.com/forums/f...ressure-51059/
To add to the practical examples listed here check out the difference in output of this boosted engine at differing compression and boost levels:
http://www.k20a.org/upload/HondaRA168EEngine.pdf
Choosing compression ratio based on proposed boost figure does not work for me... I achieve my initial power goal, get bored and go looking for more...
Cheers from a couple of fellow old school thinkers,
Glen & Jason
