Results 16 to 18 of 18
Thread: G Series Diff's
    Default Re: G Series Diff's
    Quote Originally Posted by 1JZ.747
    well heres an interesting fact for the kiddies
    at 8550rpm we crossed the line at 149.9 mph
    so im down on MPH even with the lock up activated.
    so 3.7 here we come, hopefully we can just break into the 160mph region with a 3.7
    8000=159
    8550= 169.9 (should be...how accurate is your rpm?)
    149.9/169.9 = 12% tyre slip or difference in tyre travelled circumference..
    hmm... if you have the data for the top half of the track
    you know the distance, and you know how long it took to go that distance..
    if you are logging the ECU, you know how many rpm it did at each point after that...
    so you can calculate exactly how many revs the engine did, and so how many turns of the wheels to go that distance..
    using that number of wheel revs and the expected circumference of tyre, the half track distance.... should be able to calculate it to less than 12% error.....
    or if you have a log, i can try and calc for you?
    oldcorollas, we know the converter is slipping even with the lock up, so i would say that 12% you have worked out is right. i know if i go to a billett converter we will get a 5% slip one and the MPH will increase on the same diff ratio.
    thanks for the info guys.
    8.3 et PB 169 MPH PB
    Quote Originally Posted by Mr DOHC
    that'd be scary, is there any MORE safety mods u have to do for 160mph
    nope, once fron half of the cage is in im good down to 8.00
  1. RA65 F Series diffs?
    By Hibino in forum Tech and Conversions
    Last Post: 13-01-2007, 10:23 PM
  2. need pics of f series diffs in car please
    By sam-131 in forum Tech and Conversions
    Last Post: 13-07-2006, 11:14 AM
  3. E series diffs
    Last Post: 26-06-2006, 04:57 PM
  4. F series diffs
    By whatthe? in forum Tech and Conversions
    Last Post: 17-02-2006, 10:47 AM
  5. t series diffs
    By spoon in forum Tech and Conversions
    Last Post: 03-01-2006, 12:11 AM
