Results 16 to 30 of 57
Thread: RA23/28/40 and AE71 engine crossmember comparison
    User Conversion King
    NWA
    Default Re: RA23/28/40 and AE71 engine crossmember comparison
    yeh sure....
    im going to start looking into other characteristics that will be adopted by this xmember soon.
    whats the bump steer like?
    hello
    It's good.. Seat of pants feels great.
    If I remember correctly my measurements showed a little bit of toe in on compression.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    I like Stuff Backyard Mechanic mikie's Avatar
    hey turboRA28
    what did your engineer say about the crossmember.
    iv got a ke70 crossmember cut up in similar fashion and I’m wondering what problems I might have
    cheers Mike
    NWA
    i think i smoke too much crack
    hello
    Wow this is very interesting! I always just 'assumed' ra40 and ra28 stuff was the same but you are right, they have a wider track.
    But.. 320mm you say? As xt130 is 310mm.. 320mm would be much nicer! Is this confirmed?
    Strange, I was also running RA40 LCAs in the 23 the whole time, as I had already changed the bushes in them...I didnt notice any extra track, and certainly didnt have anything resembling -tve camber This was with RA23 struts.
    NWA
    ill double check the LCA lengths this arv
    hello
    I will measure my brother's RA23 items when I am down in brissy on sat.
    Junior Member Backyard Mechanic bigmat's Avatar
    sa
    sounds like were getting closser to the ultimate rack conversion. cheers guys.
    Just a note for Sydney siders'
    Pick and Payless phone price is:
    Cross Member $50
    With rack add $60 more.
    Ill probably be getting on Saturday
    Black Betty >HERE!<
    (\__/)
    NWA
    Quote Originally Posted by TA-022
    Cross Member $50
    what happened to the RA60 rack you were playing with?
    hello
    RA28 bolt spacing 115mm
    RA60 bolt spacing 100mm
    Sadly engineer ddint like the bracketing to span the gap.
    He'd rather i chopped the ends off my std member and welded them to the RA60.
    Quite frankly that doesnt seem worth it to me.
    I'll go this AE71 for ease and look to retrofit PWR STR later depending on my opinions
    of plain RNP.
    Yes tis a sad day .... like when Video killed the radio star .... AE71 killed the RA60
    Who would have thought it... ???
    Black Betty >HERE!<
    (\__/)
    Brett, mate and luck on ra40 LCA lengths and why RA40 has more track than RA23/8?
    NWA
    im on crack
    the LCA i measured the other day probly wasnt a RA40 item. i just measured an ra40 LCA then it seems the same as the AE71.
    fucks me whats going on
    hello
    I think the RA40s just had more track at the rear, and not more at the front... seeing as the struts are identical to RA23, so are the xmembers, and there is no difference in camber. Will measure the brothers stock setup in all aspects on sats... not just the control arms.
    Brett, email them acad files to [email protected] and I will update them with RA23 measurements (if they are different at all) when I get back from brissy.
  1. Teh 4AGE into KE70/AE71 Guide!
    By phrostbyte in forum Engine & Driveline Conversions
    Last Post: 11-12-2011, 11:44 AM
  2. Fixing your stalling 4A-C Engine
    Last Post: 18-09-2006, 08:23 PM
