Results 1 to 5 of 5
Thread: MA61 into MX83 swap
    Junior Member Grease Monkey hazkell's Avatar
    Default MA61 into MX83 swap
    I have a MA61 that has pretty good running gear... I like MX83 cressidas..... You can buy parts for em......... How much stuff will bolt right up from the MA61? Will the shifter come up in the right place? will i need a custom tailshaft? Can i bolt R33 brakes straight onto the MX83?
    sorry for all the questions... but this is the right place to ask em......
    Hazkell
    vic
    Default Re: MA61 into MX83 swap
    maybe try searching ,
    If you are talking running gear, then basically nothing.
    Obviously the engine/gbox will bolt up, but you'll need MX83 mounts, different shifter position (unless you want to cut the floor). Sump is the same.
    Suspension - no.
    Tailshaft - no.
    Brakes- search.
    hmm, thats all i wanted to know, cheers guys. Sweet i wanted to use my sump, as i have a custom 7 litre one...
    That doesn't mean its going to clear the crossmember.
    It should clear, but it may not. The crossmembers are different.
    The factroy sump is small, and fits no worries, but a bigger one may be issues.
  1. How to swap a MA61 diff into your MX73?
    By RA35GT in forum Engine & Driveline Conversions
    Last Post: 30-06-2010, 11:30 PM
  2. MA61 – GH Sigma LCA Upgrade - Negative Camber + Extra Track - GUIDE
    Last Post: 06-12-2006, 11:56 PM
  3. Replies: 19
    Last Post: 03-07-2006, 08:34 AM
