im pretty sure i have some st205 injectors lying arround in a bag downstairs that i dont need
Originally Posted by BeRad
Just a side note... VVTI 1jz is top feed.
Just to add - 1JZ and jap 2JZ both high impedence which is stock.Originally Posted by Draven
US 2JZ are low impedence, and will need a resistor pack to work with your motor.
so the 540cc st205 injectors are high impedence? sounds like a better option then the US supra ones
you're running a microtech - I'm pretty sure they don't care what sort of impedance injectors you run.
something i have to find out todayI want to be pushing 18psi of boost, something around the 540cc mark should supply enough fuel shouldnt it? running a bosch 044.
044 is teh massif overkill for the power you're after - it'll be a noisy/expensive little bitch for no reason. if you don't yet have the 044, I'd recommend an 040 - will easily support 250rwkw (without even straining itself), be quieter, cheaper etc.
