Results 1 to 15 of 26
Thread: Running Locked Ignition on Carbed 4AGE
    Default Running Locked Ignition on Carbed 4AGE
    Ok, so im just thinking about ignition for one of the carby cars im building, and im very tempted to just use completely locked ignition to simplify things and drop costs. Especially since finding vac or mech advanced dizzys for 4AGs is a pain. Now i can do this with a bigport dizzy and an intelligent ignitor, and this will simply lock it at whatever the dizzy is dialed in to.
    But what im more interested in is how effective this is, or whether it will be a complete pig?
    Opinions? Ideas?
    Default Re: Running Locked Ignition on Carbed 4AGE
    I'm pretty sure Bill ran his like that for a while. Have a look at his website.
    http://www.billzilla.org/4agmods2.htm < ah its there.
    Quote Originally Posted by Bill
    The cheap & nasty way to make the dizzy work without the factory computer is to simply hook up an ignitor module (eg, Bosch) and then run the engine without any spark advance. Speaking from about 70,000km experience of this, it's really not big deal - The only hassle is that the engine can be a little hard to start when cold or very hot.
    The car wont be getting a HUGE amount of usage, and will mostly be thrashed out at Mallala, so i dont see the lack of ignition advance being overly important.
    the old jaycar programmable ignition kit would be useful in this instance.
    Of just get a vacuum advance dizzy made up out of the guts of a dizzy from a 4a.
    I did this for the 1g (well, something similar) and it cost relatively two hoots of fuck all.
    Facebook | LinkedIn
    Its recommended that you dont use vac/advanced dizzy with DCOE's (i assume by "carbed" you mean dcoe webers).
    Yeah, i was looking for that on the Jaycar website, but couldnt find any reference to it at all. Discontinued i assume?
    Quote Originally Posted by stradlater
    Define cheap? Im interested if its sub $100 or so.
    Quote Originally Posted by Screamn_Sleeka
    Close, Solexes.
    This is an interim stage to get the car running and sorted suspension wise and the driver used to the car before a GZE goes into it. GZE and all future revisions will be running off a Squirt.
    Squirt = h0rn.
    good thing is you will be able to run the SC clutch from the MS-II as well, using one of the spare outputs, which can have two conditional logic parameters...
    I've finally figured out just about everything you can do with the squirt now
    Jaycar Prog Ign is long byebye i guess by now though?
    P.s. not squirting straight up as owner wants to save some money.
    in japan, there are adaptors to use 4K dizzys in 4AG's.
    they look very simple.
    i will find pic
    edit, can't find... was just a simple spacer plate from aloy.. maybe 10mm thick??
    dunno if the drive gear was changed or not.
    SOrry - yeah prog ignition kit is gooooone! SilChip is *supposed* to be doing a new version to match with the new version HEI kit.... but of course they are slack karnts.
    Just squirt it now ya dumb bastard
    Bah, not my money im playing with. its someone elses. Which is fun, but not so good when it comes to extracting money out of aforesaid person.
    Adeladie
    Im going to be building a carb'd GE in the near future...
    I have electronic ignition on the 4AC now but its not like the normal ae82 one. It has the coil in side the dizzy. It has vac and mech advance... Alot like whats in the ST141 coronas but it was from a 4AC in the USA
    Is this the ideal dizzy that you would be after?? As in can i still use it??
    N/A 3SGE KE70 on its way
    i will find pic
    Yeh, mine is 7.5mm thick. Heres a pic -
    The other problem is the shaft diameter on the 4k dizzy is smaller than the 4ag. To allow the 4k dizzy to fit in, you have to get a spacer ring machined up to slot into the dizzy hole on the 4ag head. Theres a groove machined into the top of the ring for an oil seal aswel. Heres a pic of mine in the head.
    I'll get some measurements of the spacer ring soon.
    Drive gear is still the same i assume?
    Last Post: 17-06-2008, 08:53 PM
  2. Too Many Rules?
    By IN 05 NT in forum Toymods Car Club Membership and Feedback
    Last Post: 27-09-2006, 11:46 AM
  3. 4age running uber rich
    Last Post: 30-04-2006, 06:27 PM
  4. 4AGE 16V Running Poorly
    By SIC86 in forum Tech and Conversions
    Last Post: 09-03-2006, 07:35 AM
