Having a vacuum in the crank case is always a good thing.
It does reduce blow-by by making the rings seal better, decreases oil contamination & helps prevent oil leaks from gaskets/seals/etc.
The is the setup you want:
cam cover -> pcv valve -> catch can -> inlet manifold.
Make sure the catch can is the type that has one inlet, one outlet and a drain bolt on the bottom.
The ones that have the air filter on top are useless.
