Results 1 to 9 of 9
Thread: E58 Gearbox: LSD or Not?
    Extreme Procrastinator Grease Monkey PuGZoR's Avatar
    Default E58 Gearbox: LSD or Not?
    Hey all,
    As hundreds of others have done, I got an AE101 Levin 4AGZE frontcut and took the engine out for my sprinter. How do I tell if the E58 is LSD or not? Is there anything I can do other than putting the driveshafts in and spinning them? Is there anything on Vin plates or whatever?
    Searching = useless because search ignores anything 3 letters or less, so E58 and LSD are both out of the question...
    Thanks.
    Insert whitty comment her Automotive Encyclopaedia blacktop's Avatar
    Aug 2006
    Default Re: E58 Gearbox: LSD or Not?
    Thanks. I'll keep looking around I guess unless someone has anything more definitive...
    spin one of the output splines, and see if the other side spins the same way or not.
    Otherwise, check the vehicle ID plate on the frontcut it came from.
    ...... butt scratcher?!
    What do I look for on the VIN to know if it's LSD or not though? I have it, I just can't find anyone that knows what or where a code that means it's LSD is...
    if the trans id is E58-11C, then it's was built at the factory with LSD. The C means it has LSD.
    you could also read the FAQ i wrote....
    http://www.toymods.net/forums/showthread.php?t=141
    Good FAQ. Sorry, was a bit hard to search for everything because of the stupid 4 char minimum on search keywords. Mine's LSD then.
    Or, you could just pull the speedo drive unit out and have a look at the diff..
  1. Verifying a w58 gearbox
    Last Post: 09-10-2008, 10:39 PM
  2. How-to: Converting an MR2 gearbox to FWD (SW20 to ST162)
    By buck naked in forum Tech and Conversions
    Last Post: 27-12-2006, 06:22 PM
  3. SW20 turbo gearbox to FWD
    By draza in forum Engine & Driveline Conversions
    Last Post: 29-03-2006, 10:34 PM
  4. AE86 Gearbox Conversion Options
    By Garth AE86 in forum Tech and Conversions
    Last Post: 20-03-2006, 01:30 AM
