FWIW I have a 2K sitting downstairs. It's out of the KP-60 Starlet I have, and it's a one litre thing of about 45hp I think.Originally Posted by oldcorollas
There's also a lot to be done to make the oil pump work properly - We ended up having to spend a lot of time on the one we had in the 3K full-race engine we ran for a few years.
They're pretty crappy standard, and so what we did to make the oil system work better was to put the pump body in the lathe and machine three grooves in the shaft that runs from the pump body up to the cam gear drive. The grooves were for o-rings, and they kept the oil pressure from squirting out into the gap around that long shaft top & bottom and so losing pressure.
The small hole up near the top that squirts oil out onto the drive gear also needs to be drilled out a little to improve the flow onto the gear, as with a big cam and lots of revs they wear out quickly.
We also fiddled with the profiles of the internal passeges a fair bit inside the pump body to improve the flow.
The big nut that holds the pressure relief valve in place also can sometimes come undone, leaving you with a maximum of about 20 - 30psi at any revs. We had that happen so they always got lock-wired in place after that.
might be a 5k or a 7k though, not to sore?
