That being said, i've noticed on occassions (and i think much more frequently after first connecting it, less so now???) that mine still rev cut occasionally at just under or around 8k, seemed a couple of hundred rpm short. Mainly 1st and 2nd gear, but i'd get caught out by it hitting the limiter a bit earlier than expected or it seemed to cut at different points from one shift to the next. Does seem to have stopped doing that and maybe i rely more on my ear these days too.
I did think this could be lag in the tacho indicating a bit less than actual revs as i've definitely seen my tacho indicating way less than my ears and limiter are telling it's doing - say after a big couple of blips on a downshift when the tacho's swept right up twice then in gear and full throttle from 7k or so - tacho has still been at 7,7-ish when it's definitely 8+ and confirmed with the limiter.
That's very occasionally but an example of what i'm talking about but exaggerated - finally getting around to my point, maybe it is actually at 8,2 but your tacho was lagging a little and only looked like just on 8? Check your engine codes, if there's any issue with the speed signal you'll get the code for it. If not, you're at an 8,2 limit. Does it hit 8,2 some of the time?
