id keep the AC Compressor...id just not connect it...easier than phucking around making idler pulleys and custom belts..
-good plan - just be aware some engines might have that odd-bod no clutch setup?
tow legality is of little concern...im talking a max trip of 40-50kms to mallala and it tows fine now...
-i did say "IF"
wouldn't bother me either.
In regards to rear tyres id probably up the rim size to a 15" ford steelie and get it widened to a 9 at the rear (galpro can do it here for under $200 a pair) then whack on some nice old school BFG street 295 15's
-make sure they are the right offset or you won't fit them, also they need to be appropriately load rated for rego - get a big brake setup too.
i dont do "3RZ"...1JZ is factory turbo...
The thing handles like a wet fish now...i recognise its no circuit warrior and never will be
piffle![]()
It makes some scraping noises on occasion, unfortunately I don't have the time or money to replace it at the moment. I haven't seen any ill side effects yet and would imagine that any pieces would be caught in the intercooler. If your replacing the head gasket you should be able to see if there is any damage to the cylinders or pistons. Not sure if it would be from thrashing or just bearings worn with age.
