Results 1 to 15 of 15
Thread: Guide: Using Modifying MS85 hubs to fit MA61 etc
    Default Guide: Using Modifying MS85 hubs to fit MA61 etc
    This came up in another thread recently so I spent a few mins tidying up the document that I put together for myself when I was modifying my MS85 hubs to fit my MA61...
    The short story is that MS85 hubs can fit MA61 with some machining and different bearings. Bear in mind that the bearings required are much, MUCH more expensive than the stock MA61 etc bearing kit...and they can't be bought in a kit to my knowledge...
    Might be of some use to others!
    PDF HERE!!!!!
    Default Re: Guide: Using Modifying MS85 hubs to fit MA61 etc
    WHOA! Great guide, really well presented +rep!
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    Wow, it seem very well documented from my skim read. I'll have to study this one in more depth later. Well done
    I always wondered if you could use em.... no doubt the cost outweighs the benefit.
    User Conversion King
    NWA
    nice!
    but does the 'extra' cost of the bearings and labour in machining outweigh the extravagent price of MS65 hubs these days? (unless you can get them free )
    hello
    Tas
    Its not the price of the ms65 hubs its the fact there just arent any around. Supply and demand of ms65 hubs = big $$, but if there is no supply ......
    in discusion with wilbo, this method of machining the hubs is labour intensive.
    To get a machining shop to to the job and supply bearing would be around $300-400. The bearings are nearly $100 and the machining requires lots of checking during the job (if you remove too much metal, the bearing cups are not captive and you end up with a hub-shaped paper-weight).
    So it's still cheaper to locate MS65 hubs (last i saw was $100/pair + postage).
    NWA
    i should put some ms65 hubs on ebay and see what they go for
    hello
    how about you gift me a pair for being nice guy?
    The bearings are macho more expensive, i think the bearings were around $130 from memory!
    If you have access to a lathe, and you get the hubs for what they are worth (next to nothing ) then the extra cost of the bearings is offset by the money saved on the hubs...still the individual will have to decide if it is worth it
    The only reason that I did this was that I was sent the MS85 hubs as MS65 hubs I was pressed for time to get the car back together and on the road (for last years Toyota Nationals )...
    Tas
    I'll happily pay quite a bit more than $100 + postage if anyone has a spare set
    Yeah, im paying $60 for 1 hub from a local source.
    Thank god I managed to get 1 from a wrecker a few months back.
    However, having thrown out a set of ms85 and z31t hubs.. made it an expensive excercise
    But atleast this is another option as ms85 hubs are plentiful.
    Daily: '06 Liberty 3.0R specB
    Slighty off topic, but i think very relavent, what wheels will suit?
    It's 5x100 isnt it? So all the ford wheels will "fit" but the newer ford's will be the wrong offset?
    What mm spacers are needed to make new ford (EA etc) wheels fit properly? and will this be the same as skylines and any other cars?
    Quote Originally Posted by Screamn_Sleeka
    The stud pattern is 5x114.3. The same as Ford, Nissan, etc
    Ford wheels will fit, pre AU wheels will have offsets that should work. Post AU will need spacers. (btw EA is OLD Ford, not new )
    Offset is pretty well the same as factory MA61 (maybe +- a few mm, nothing major).
    17x8 + 35 wheels need an ~13mm spacer to clear the struts with 235/45/17 tyres.
    Most of this can be found for simply searching for info on MS65 hubs....
    also peoples, MS112 and MS123 Hubs are also the same as MS85 therefore they will fit with this modification.
  1. MA61 Part Numbers & General Infomation
    Last Post: 27-03-2013, 01:31 AM
  2. ma61 front end upgrade writeup.
    By nb86 in forum Tech and Conversions
    Last Post: 22-07-2009, 11:24 PM
  3. MA61 – GH Sigma LCA Upgrade - Negative Camber + Extra Track - GUIDE
    Last Post: 07-12-2006, 12:56 AM
