Results 1 to 15 of 30
Thread: ECU pinouts Gen 3 1GGZE (Definitive?)
    Default ECU pinouts Gen 3 1GGZE (Definitive?)
    I rec'd the attached XL spreadsheet from Adam (Bullfrog) which contained the ECU pinouts for the Gen 3 1GGZE, almost complete with colour-coding of the wires and plugs.
    Looking at my loom, which was intact for the ECU plugs labelled "R" and "S", I was able to confirm most of the colour-coding with a few corrections. Ditto for the plugs labelled "Y", "W" and "X".
    Looking at my ECU plug labelled "O" it had been cut about 50mm up the wire so I was able to fill in the wire colours for this plug.
    All the corrections and my additions are in bold red on the spreadsheet.
    Plug "Y" - changes to pins 12 and 13
    Plug "X" - changes to pins 2 and 7. 12 was BLANK on my plug.
    Plug "W" - changes to pin 4, and pin 3 is not BLANK (pale grn/ylw stripe)
    ECU Plug "O" - all wire colours added
    ECU Plug "S" and "R" not checked (but I will do so ASAP).
    If anyone would like to comment and/or confirm these pinouts I would welcome that as I am about to look at the wire-up in the next day or so. I've converted the file to PDF for download from my website (56Kb).
    http://users.tpg.com.au/adslljrb/rn8...n3_amended.pdf
    cheers,
    Peter
    Junior Member 1st year Apprentice Bullfrog's Avatar
    victoria
    Default Re: ECU pinouts Gen 3 1GGZE (Definitive?)
    Hi All,
    Well after some mucking around some and little bit of time in the shed with the multimeter i think i have sorted out a wiring diagram modified from a previous post for the 1ggte gen3 engine.
    I have done an edited version for the 1ggze gen 3 as i couldn't find one anywhere so here it is i know there are some lecko's and people who have done a conversion with the engine and may know the wiring backwards on the threads so if you could take a couple minutes to check it out and edit or let me know if there are any problems with it .
    Thanks all and hope it helps With your conversion's
    Also here is an updated version for the ecu pinouts i have pretty much just changed the plugs and added the auto plug aswell.
    Hilux RN110
    1G-GZE Gen 3 Conversion currently underway
    Dude, this is fantastic except as they are above even when printed in HiRes are not all that readable.
    Can you post the last graphic in its original XL format?
    The other 4 wiring schematics will need to be much larger in filesize for them to print out and use. Or save them in a higher resolution format like TIFF or BITMAP.
    Can you email them to me?
    Peter
    Here are the Hi(gher) Resolution images of Bullfrog's wiring for the Gen 3 1G-GZE. I've used Adobe Photoshop to clean up some of the lines and the labels, but the credit should go to Bullfrog (Adam):
    You can download them from my website:
    1G-GZE Wiring Gen 3 - Page 1 - JPG - 360Kb
    http://users.tpg.com.au/adslljrb/1GG...diagram P1.JPG
    1G-GZE Wiring Gen 3 - Page 2 - JPG - 454Kb
    http://users.tpg.com.au/adslljrb/1GG...diagram P2.JPG
    1G-GZE Wiring Gen 3 - Page 3 - JPG - 471Kb
    http://users.tpg.com.au/adslljrb/1GG...diagram P3.JPG
    1G-GZE Wiring Gen 3 - Page 4 - JPG - 294Kb
    http://users.tpg.com.au/adslljrb/1GG...diagram P4.JPG
    1G-GZE Colour Coded Wiring and Plug Spreadsheet
    This is converted to Adobe PDF - 104Kb
    http://users.tpg.com.au/adslljrb/1GG...1ggze Gen3.pdf
    Cheers, and +rep to Bullfrog for his outstanding effort.
    Peter
    Mad Man Grease Monkey 77GZE's Avatar
    Big help guys, good effort
    Not being electrically minded, can someone explain what the symbols in this wiring diagram are?
    Hoppers Crossing
    peter - they're normally connectors mate.
    victoria
    Grega is spot on peter the one you are pointing at is pin number 2 in plug 2C to be exact.
    Hilux RN110
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    I popped the cover of my old 1G ECU to check the pinouts. The codes are printed beside each pin on the PCB. No guess-work if you do it that way.
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
    Quote Originally Posted by Sir_2jza70
    Yeah, I had a look and confirmed all the pins in Bullfrog's ECU schematics. Great stuff.
    Here's a couple of questions I'd like answered if possible.
    I want to connect a Boost gauge. Can I connect it at this point on the engine?
    Where do these two wires go? It comes up from underneath the AC unit (two black wires) to a grey plug receptacle. Into this is a blue plug with a Dark Green/White & Dark Green/Yellow wires. Where do I connect the two Dark Green wires? I noticed the same connector on my friend's engine so they must connect to the original 22R loom on the driver's side. His plug was Black/White & Red/White.
    I got a fuel pump resistor from a Cressida. It has three wires and a "6" stamped on it. I've mounted it and there is a plug on the 1GGZE loom that is the same but a different colour. Is this where it connects or is that too easy? Is it the same as the one Bullfrog showed me with two wires and a "4" on it? I noticed at Pick 'n' Payless there were three variants with another Toyota having 4 wires.
    Peter
    victoria
    infotechplus,
    I can answer one of your questions about the boost gauge one at the moment would have to look into the other ones i think you will find that the hose you are looking at goes to your charcaol canester its on the wrong side of the s/c as there should be no boost that side. As for where to go for a boost gauge no idea i know when i turn the s/c over by hand there is pressure in the pipe that runs infront of the head, got know idea what it is for yet. not sure if the standard car had a boost gauge so it may plug and play so to speak.
    Hilux RN110
    victoria
    Sorry mate just had a thought.. Do you have a/c in the ute already if so check the colors of the wires that come from the ac switch in the dash i seem to remember those being green in my lux will have a look over the weekend.
    Hilux RN110
    Quote Originally Posted by Bullfrog
    infotechplus,
    No, the charcoal canister tubing is on the right angle pipe to the right of the question mark, above the larger pipe (according to another to Toymodder) and I think this is correct.
    The pipe I'm using was suggested by another person and SSS Automotive. I just wanted to confirm.
    [Edit] Well I think you are right Adam, as this photo confirms (from Glen's Celica 1GGZE install).
    I want to run a Vacuum gauge as well as the Boost gauge so I'll use a Tee piece to split the hose under the dash.
    The AC switch on the dash has 5 wires:
    Blue w/White stripe
    Green
    White w/Black stripe (2 of these)
    Black w/Red or Brown stripe
    Sheebz Automotive Grease Monkey Gleno28's Avatar
    I've got my boost/vac gauge running out of the Power steering?? vac point at the front of the manifold. Not sure if you can t piece it but it works fine from here.
    Glen.
    A lone crusader, in a dangerous world of low reputation...
    ST141 Corona, VZN130 4Runner, 4AGE KE70 Pan Van
    18RG RA28
    1GGZE RA28
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 08:10 AM
  2. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 07:31 AM
  3. **bad info** 4agze Ecu
    By progkamol in forum Tech and Conversions
    Last Post: 26-07-2006, 05:38 PM
  4. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 11:17 AM
  5. How to connect switches to switched pinouts on a toyota ECU?
    By 2JZR31 in forum Tech and Conversions
    Last Post: 31-03-2006, 04:04 PM
