Results 1 to 7 of 7
Thread: ke20/25 camber plates
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    Default ke20/25 camber plates
    what amount of neg camber can be achieved?
    also:
    whiteline
    noltec
    t3
    kmac
    all make camber plates, any recommendation on brand or type?
    Jun 2006
    Default Re: ke20/25 camber plates
    well seems that with stock springs, almost nil.
    with smaller springs, eg coil overs maybe -1 deg total
    depending on camber plate brand.
    sooo probably going to go negative camber roll centre adjusters then,
    as the ke20/25 had long control arms and there arent many suitable arms to swap with
    past 335mm except mx62's at 360mm (unsure of balljoint interchangability though)
    umm, 10mm = approx 1 deg camber.
    with my home made ones on KE1X, i get an extra 20mm of castor and camber (= 2deg of each)
    how much camber do you need? how much space is there between spring and the panel? surely more than 10mm?
    I'm currently have coilovers fitted to my r31 struts using t3 plates for my ke20, and i'm expecting considerably more than 1 deg, 1 deg will bring me back to standard as the kinpin angle of R31 is 1 deg more positive..
    0402727834 Grease Monkey turbo ke20's Avatar
    im running ke55 control arms with celica struts and if anything i have a bit of postive camber
    noltec make the adjustable camber top but they are $400 from memory.
    u can always try a set of these adjustable control arms.
    they will need a bit of wirk to get them to work 100%
    pm me if interested but.
    justin
    With my gheyer than aids K-Mac strut tops I have an incredible negative camber of 0'30" dialled in. That is as much as the camber tops will allow and this is running a coilover over setup too so I have an incredibly large amount of room to play with inside the strut tower.
    K-Mac strut tops are a good strut top but not a good adjustable strut top, not on the early corollas anyway.
    Quote Originally Posted by turbo ke20
    I was under the impression that adjustable control arms were illegal (in NSW at least)?
    0'30" is a bit disappointing for an adjustable top.. What is stock? I'll let you all know how i go with the T3 ones once they're in the car..
    (On the note of T3 Shane, still no reply. I'll probably just ring him if it goes on much longer).
  1. RA28 KMAC camber tops
    By Snyper in forum Tech and Conversions
    Last Post: 17-10-2006, 07:08 AM
  2. camber adjustment for st162
    Last Post: 29-04-2006, 07:38 AM
